06-11-2014, 08:01 PM | #1 |
342
Rep 1,805
My old e92 m3 vs current e46 m3 - corner balance sheet weights
E46 on Left / E92 on Right
Both with KW clubsports, e92 had on track wheels but stock exhaust except dinan muffler and secondary cat delete. E46 has header and full car delete but added a center muffler and on stock 19's Weighed without aero
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 Last edited by TheKosherStogie; 06-17-2014 at 04:37 PM.. |
06-11-2014, 08:07 PM | #3 |
342
Rep 1,805
fixed
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
06-11-2014, 08:24 PM | #4 |
115
Rep 1,470
Info on the aero please and how easy it to remove to not look like a dork on the street or rip off that lip.
Maybe it's the angle of the pic, but it looks like the rear wing is giving you lift
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
06-11-2014, 08:41 PM | #6 |
Riding the knock sensor
2383
Rep 1,598
Drives: 21 X5MC | 23 M4CSL
More rake on the E92? Was WE able the get it closer?
06-11-2014, 08:46 PM | #7 |
2383
Rep 1,598
06-11-2014, 09:51 PM | #9 | ||
342
Rep 1,805
Correct, but even at an UP angle the wing still provides tons of downforce! I was trying to reduce understeer the aero brought so I kept lifting the angle of the wing, ideally you want the least amount of wing you need (less drag). I was still full throttle thru turn 8 at WSIR at 130mph The splitter is not easy to remove and not something you can just take on and off. Lots of attachment points/bolts
06-17-2014, 04:36 PM | #11 |
342
Rep 1,805
it didn't get lighter...its about 150lbs heavier...
06-17-2014, 07:33 PM | #12 |
3663
Rep 3,422
Looks like you had the E92 pretty well set up. Why did you move to an E46? (Not that there's anything wrong with that.)
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
06-17-2014, 07:48 PM | #13 |
1578
Rep 8,077
Drives: 11 E90 M3 Individual
If the E46 had the stock exhaust and the E90 had a dinan rear section...that could account for some of the front heaviness on the E90.
I was surprised at how heavy the stock exhaust is on both cars as I was holding then up over my head whimpering for help. Yeah, I tried to make it a one person job both times...mistake.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
06-17-2014, 09:23 PM | #14 | |
59
Rep 1,250
06-17-2014, 10:37 PM | #15 |
1578
Rep 8,077
And its so awkward its like holding up 100lbs. I ended up just dropping my E46M3 exhaust on the floor since no one came to help (they just laughed) and its pretty much worthless.
06-17-2014, 11:56 PM | #16 | |
342
Rep 1,805
Also the e46 has aftermarket headers and borla The e92 only had a dinan muffler. Both had KW's. |
06-18-2014, 05:31 AM | #17 | |
21124
Rep 20,742
Drives: 2021 911 turbo
How much fuel in each car? Is the weight with driver (I suspect not)? |
06-18-2014, 06:46 AM | #18 |
2736
Rep 3,354
The spec sheet says with driver. Curious how much the driver weighed....
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
06-18-2014, 06:52 AM | #19 |
21124
Rep 20,742
06-18-2014, 07:45 AM | #20 | |
342
Rep 1,805
The weights are WITH driver. I weigh 175-180 E92 had 1/2 tank, e46 3/4 tank. Last edited by TheKosherStogie; 06-18-2014 at 07:54 AM.. |
06-18-2014, 03:01 PM | #21 |
Track? What Track? I was just riding along . . .
46
Rep 694
06-19-2014, 09:37 AM | #22 |
2760
Rep 5,483
Interesting stuff. My E90 with half tank is about 3570 without driver, about 3755 with, but that's with about 50lb lost in wheels, front brakes and MPE. If you take out all the trunk junk and misc. crap in the car it's closer to 3735 with driver. However, the weight distribution is more even, 50.4% front with driver and 50.8% cross weight and that's without coilovers and with a slightly heavier than stock front suspension setup (steel MCS dampers and solid RDSport bar)
