TireRack
      06-10-2014, 03:10 PM   #1
moeenulhaq
Drives: 2011 X5
2011 X5 Maintenance Schedule
May be this a re-post but i am looking for a maintenance schedule for my 2011 X5 , i ve got 57k mile on it and don't want to go with extended warranty or maintenance package being offered by BMW.
Being a DIY savvy i believe i should be able to handle most of the regular maintenance items such as filters , plugs, oil , brakes etc.
Secondly, are there any known problems that can happen at higher miles for e.g.: bad water pump at xxxxx miles? or a belt change may be?
Please Help!
FYI - its a used X5 and didn't come with owners manual that i can refer too for help.
      06-10-2014, 03:25 PM   #2
mitch808
107
Drives: 2012 X5 35i
You can go to BMW's site, register there and your car VIN to download manuals for your car.
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
      06-10-2014, 03:53 PM   #3
moeenulhaq
Drives: 2011 X5
I downloaded it but it can't seem to find it in there unless its missing maintenance schedule.
      06-10-2014, 03:54 PM   #4
moeenulhaq
Drives: 2011 X5
Does anyone know what things are prone to go bad at what mileage?
      06-10-2014, 04:53 PM   #5
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Let's just say I'd never own one without a warranty. My friend had a 2008 X5 3.0. He bought it when it was still under warranty, but decided to roll the dice and not get an extended warranty. Not even half a year later, he had already spend thousands replacing the A/C and dealing with an engine that was leaking oil. Quite a bit more than an extended warranty would have cost him.
He finally just ditched it and bought a Tahoe this year.
      06-10-2014, 05:08 PM   #6
mitch808
107
Drives: 2012 X5 35i
Other than what the onboard computer tells you through the menus, this guide mentions somethings:
http://www.bmwsections.com/docs/x5/
You can google harder than I did, all I used was "e70 maintenance."
      06-10-2014, 09:00 PM   #7
moeenulhaq
Drives: 2011 X5
Interesting… Thanks …. now i gotta decide even harder
      06-10-2014, 09:01 PM   #8
moeenulhaq
Drives: 2011 X5
This is really helpful … Thanks
      06-10-2014, 09:03 PM   #9
moeenulhaq
Drives: 2011 X5
Actually i downloaded this manual after registering at BMW. It does not have any scheduled maintenance schedule.
      06-10-2014, 09:10 PM   #10
mitch808
107
Drives: 2012 X5 35i
But it has a section on maintenance right, which refers you to mainly the onboard computer and service info... There is your answer.
      06-12-2014, 11:00 PM   #11
MRV99
MRV99's Avatar
254
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
That is no such thing as a maintenance schedule on a modern BMW. When the computer alerts you to maintenance, you do it. Not that I agree with that but that is the reality. There are some items which are not in the computer like spark plugs on the TT motor I think are 45k miles. The best bet is go go by the old school schedules of the past. I would start by cutting that 15k oil service down to 7500ish.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      08-12-2019, 09:38 PM   #12
greg328
Drives: 2011 X5 MSport
What about the ZF8 transmission? Is it lifetime fluid, or does it need drain/refill at certain mileage/time? My 2011 had 70, xxx miles on it currently.
      09-07-2019, 09:51 PM   #13
Alex Ander
Drives: BMW X5 xDrive3.5i 2013
It is better to do it between 60k to 80k miles.
I did mine at 60k even if it was working flawlessly.
After the fluid change, there has been a small improvement in smoothness between gear shifts and better MPG.
      09-08-2019, 02:49 PM   #14
Poppyboy
194
Drives: 2011 X5 3.5i w/ SA Package
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
No fluid is lifetime, no matter what they say. I did the fluid and pan/filter at 58k miles on my ‘11 ZF8. I bought the kit delivered from FCPEuro for $254. It was a bit of a pain to follow the process and procedure, but saved me hundreds, and was very satisfying to know it was done right.
      09-08-2019, 06:04 PM   #15
greg328
Is this the kit you bought? It's less $$ than you mentioned..
https://www.fcpeuro.com/products/bmw...-24118612901kt
Greg
      09-08-2019, 09:23 PM   #16
Poppyboy
194
2011 X5  [10.00]
Nope. I bought the kit with OEM ZF fluid. Probably not a significant difference. I just thought since this would be the only time I change it, I’d go OEM all the way.
xbimmers
