05-23-2014, 08:33 AM | #1 |
Rep 92
Alignment After KW Install
Is it a must to get an alignment after a Coilover install?
Interested in your thoughts as I've seen conflicting info on this. Thanks! Joe |
05-23-2014, 09:51 AM | #3 | |
Rep 92
I've heard some say alignment could get way out of sack and others say it's a very minimal issue. |
05-23-2014, 10:19 AM | #4 |
67
Rep 1,023
it will 100% be way out of wack.
when lowering you toe will always be different. you will get excessive inner wear. i put on springs and didnt even unhook much in the rear, and the toe was very off. you are unbolting everything in the front. it will be very out of wack |
05-23-2014, 10:48 AM | #5 |
107
Rep 994
When you lower a car, not only will you get negative camber (tops of tires tip inward), the tires will also toe-in, (point inward). At least for the front end. The rear end is simply camber in most cases.
Toe is the biggest killer of tires. Not camber. I could run 3 deg of negative camber and my tires when properly rotated, would still last a very long time. But .5 deg of toe, I'll probably kill half the life of my tires if not more. That said on an X5, you can adjust camber in the rear, you can adjust toe up front, but you will require parts up front IIRC to change camber. However, camber is a good thing, and under -2.0 on a street car, is just fine. Shoot for 0.0 toe on both sides.
2012 X5 xDrive35i Sport Activity - Alpine White - M Sport Package
05-23-2014, 11:16 AM | #6 |
307
Rep 1,715
Drives: 2014 650xi Gran Coupe Msport
you just spent 3K on coilovers. Don't cheap out on a $100 alignment and destroy $1500 in tires in the process.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
05-23-2014, 11:21 AM | #7 | |
Rep 92
