03-30-2014, 04:08 PM | #1 |
Rep 75
HELP!: Stripped Rotor Set-Screw
During an attempted front rotor replacement on my 135i I managed to strip the hex head of the 6mm set screw (don't ask ). So now it's round and there's no way any size of hex or torx will get a grip on it. The screw is also in there pretty tight, which is why it stripped in the first place. Any tips on the best way to get this thing out at this point? Would a screw extractor have any hope of working on this or is it unlikely to be able to hold the torque? If a screw extractor is a good option, what size?
Thx |
03-30-2014, 05:56 PM | #2 |
340
Rep 1,293
Soak it with PB Blast, Liquid Wrench or CRC Freeze Off and let it sit for at least 30 minutes. You can pick up a whole set of screw extractors at Harbor Freigt for under $10. This happened to me on an old VW GTI. After soaking it with PB Blast, I hammered a large flat head screw driver into the bolt and got it to turn with almost zero effort.
03-30-2014, 06:38 PM | #3 |
23
Rep 110
Just drill it out with a bit a little larger than the threaded portion. Once the head is removed you can remove the rotor and the remaining screw should come out relatively easily. If not, grind flats on it and remove with a wrench.
These don't need to be tight at all. They just hold the rotor in place until you get the wheels on. Use anti-seize on the new one. |
03-30-2014, 06:39 PM | #4 |
24
Rep 265
For next time... These are worth every penny.
2009 135i - SG/Coral - 19" Alufelgen SF-71 - ST Coilovers - Cobb Stage 2+ - AR Downpipes - Berk Sport Exhaust - Active Autowerke Charge Pipe - AMS FMIC - AFE DCI - LUX V3 Angel Eyes - LCI Blacklines - Active Autowerke Strut Tower Brace - BMW Performance CF Spoiler - Kerscher Carbon Splitter - Scopian CF Diffuser - MusicarNW Level 2
03-30-2014, 07:49 PM | #5 |
Rep 75
Thanks for the suggestions. Yes, I should have used a correct fitting hex driver from the outset instead of an allen key and my jack handle. I have one now to do the others.
04-06-2014, 05:44 AM | #6 |
23
Rep 111
The suggestion is to use an impact gun / screwdriver - the impact really helps get these free.
As for the screw itself, same exact thing happened to me, I drilled it out (w/o screw extractor). Once the bulk of the screw was gone, it came out pretty easily. |
04-06-2014, 04:25 PM | #8 | |
European Editor
10594
Rep 22,992
I have a T27 that I use for this very thing. A T25 is too small and a T30 is too big. A T27 is just right for the brake rotor set screws. Sometimes it helps to spray down the set screw bolt with WD40 or LiquidWrench... let it sit for a while. Then use a 8mm punch on the head of the set screw with a BFG(Big F-ing Hammer) giving it a nice Luv tap! Don't be shy either with the LUV!! That will "wake up" thread rust and then you can tap on the T27 and turn it SLOWLY. IF that strips... use an easy out. Another method is what a mechanic friend would say is the Gorillia technique! Since you are replacing your rotors... once you have removed the brake caliper and bracket... use your BFG hammer(5 kg or larger) and WHACK the back of the rotor off the hub. This will "pop" the head of the set screw off and the rotor will fall off. Good Luck, Dackel
04-07-2014, 07:03 PM | #9 |
Rep 75
Good idea with the over-sized torx driver. I ended-up drilling it until the head popped off and then I pulled off the rotor and got the threaded part out with an extractor. I used a hex driver on the rest of the set screws and they all came out like butter.
04-07-2014, 07:10 PM | #10 | |
European Editor
10594
Rep 22,992
I forgot to mention that using a zinc anti-seize on the new screw will help the "next guy" doing a brake job. I also use zinc anti-seize around the hub and wheel bolt area - so the alloy wheel doesn't stick to the hub.
04-08-2014, 02:47 PM | #11 |
37
Rep 131
get a drill, and drill a small hole in the middle of the screw....then get one of those Harbor Freight screw extractors and using that hole as a guide screw the extractor in there and that should work...(pb blaster optional but personally for me I didn't need it)
04-08-2014, 07:50 PM | #12 |
54
Rep 246
Here's how you get it out....take a Dremel with a cut-off disc and grind a straight, deep slot right across the screw...if you go into the rotor a little, don't worry, no biggie....now get an impact screw driver, one of those you hit with a hammer...put the biggest blade in the driver that'll fit the slot you cut...make the slot bigger if you have to....make sure the impact driver is set to "remove" and give a very serious wack with a large hammer or small sledge...wear a welding glove on your left hand if you're a lousy shot...whatever, but you got to really hit, and on the first shot...
'13 128i 6sp, '19 Cherokee Ltd 3.2, '17 Ducati SuperSport S Gone But Not Forgotten: 74 Z28, 77 Datsun 280Z (1st 5sp in US), 92 Nissan 300ZTT, 94 MB SL600 V12, 01 M Roadster, 66 Yamaha TwinJet 100, 70 Suzuki X6 Hustler Race: GP/FP Spitfire SCCA, Merlyn FF SCCA, Mazda RX7 IMSA GTU, Yamaha FZR 400 AMA.
