03-16-2014, 08:27 PM | #1 |
Schumacher
791
Rep 2,282
Drives: E30 325is,E93 M3,X7M50,F06 M6
Help Opening headlights
I was thinking of doing the OSS rings on my car. I could send the lights out, and I may still do that, but I am wondering if anyone has done this in the Chicago area and could help me try a DIY.
03-16-2014, 10:15 PM | #2 |
27
Rep 472
I did a similar mod to my MINI headlights, which is basically the same mod. I didn't bake it, instead using a heat gun and a thin flathead, working around it. It can be messy but I feel its safer than baking my whole headlight.
03-17-2014, 09:22 AM | #3 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
yeah i dont know if I feel good about baking my headlights either, I have done many other headlights in the past, but never had the balls to do the m3s. OP if your going to do it I am willing to give you a hand
03-17-2014, 09:34 AM | #4 |
Schumacher
791
Rep 2,282
Im a bit nervous about this but I like the heat gun idea. Maybe once the weather gets a bit warmer its something we can look at.
03-17-2014, 10:02 AM | #5 |
52
Rep 418
i did this with a few sets of STi headlights back when i had mine. It is definitely alot more ballsy to do it with M3 headlights but if you were to try it, i believe the oven was set at 210-215 and they bake about 10-12 minutes, but check them frequently to see if they need to go a little longer or if the sealant is ready early.
03-17-2014, 10:15 AM | #6 |
///M
62
Rep 1,124
Honestly, I would just send them out to OSS ... The risk of moisture seeping in after your DIY job and time invested might not be worth it in the end ... Luis@OSSdesigns does great work!!!
03-17-2014, 01:10 PM | #8 | |
569
Rep 3,742
I did it myself on my Mini headlights and it worked great. I put them in the oven at ~200 for 10-12 minutes. It really isn't as bad as you think. After you do the first one, you realize it's not so scary. I ended up sending my M3 headlights to Luis @ OSS (and am about to send out my Z4 ones) only because I didn't want to mess with the wiring for the LED angle eyes which is over my head. But if you are just looking to paint them (as I was on the Mini), it's pretty easy to DIY. Search "Joey Mod" for DIYs; its the same procedure with Mini and BMW headlights. |
03-17-2014, 04:10 PM | #9 | |
///M
62
Rep 1,124
03-17-2014, 09:27 PM | #10 | |
569
Rep 3,742
03-17-2014, 09:37 PM | #11 | ||
///M
62
Rep 1,124
