03-15-2014, 10:31 AM | #1 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
BBS Motorsports E05 - (AKA BBS FI 3-Piece)
I have gone on a bit of a wheel binge this month and this is the final set. These wheels are absolutely stunning in person. I plan to keep these but I guess I would let them go for the right price
Once again the front lip is a Mode Carbon GT4. A pro shoot will be coming soon. BBS Motorsports E05 Satin black centers with black anodized lips and barrels 18 x 10 et 25 (with a 10mm spacer - effective et15) (2" lip) 275/35/18 BF Goodrich G-Force Rivals * Front tires rub the fender. As you can see in the pictures, the front wheels are very aggressive and I'm going to need to add some negative camber. I'm at -2.0 degrees now and will need to go to somewhere closer to -2.5 degrees. 18 x 11 et 25 (3" lip) 295/35/18 BF Goodrich G-Force Rivals * No Rubbing I wanted to test out these new BFG tires which are made to compete with the AD08's, RS3's, etc in the "extreme performance" category. I have not yet tested their performance but I can say that they run very wide. I was also motivated to try them because they are one of the few tires available in 295/35/18 and 275/35/18 which are a great match to the OEM tire diameters. I will give a review of the tire once I have had a chance to run them for a while.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 03-16-2014 at 10:04 AM.. |
03-15-2014, 10:42 AM | #2 |
376
Rep 4,089
Drives: 21 X6MC
Nice!!!!! Did you get the weight measurements?
03-15-2014, 10:54 AM | #3 |
2739
Rep 6,734
Unfortunately I did not. I don't have a decent scale. I tried using my cheap bathroom scale and the weights were inconsistent.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
03-15-2014, 11:00 AM | #4 |
376
Rep 4,089
Drives: 21 X6MC
03-15-2014, 11:13 AM | #5 |
2739
Rep 6,734
Because with the centers that BBS had/has my only options in 10" were et25 and et13. After receiving feedback from me and others, BBS will be machining a second center option that will yield a 10" et19 which is what I would have probably chosen if it were readily available. In the end I'm glad I didn't wait for the et19 version because it would have required 5mm spacers due to the width of these tires (et19 would work for a more conservative tire in the same size - like Michelin PSS). In addition, 10" et25 is a common option used by many people (apex wheels are available in 10" et25) and I think it will be easier to sell that more conservative offset if/when I sell the wheels. Knowing what I know now, I would consider et13 but that is a very aggressive offset that most people would fear (making them more difficult to sell). Spacers are not a bad thing when it comes to aggressive fitment. It's hard to pinpoint the perfect offset when taking into consideration tire size variations and when you have mm's to play with. Lastly, an offset that is too conservative can always be corrected with spacers, an offset that is too aggressive can't be fixed....
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 03-15-2014 at 11:30 AM.. |
03-15-2014, 11:20 AM | #6 | |
376
Rep 4,089
Drives: 21 X6MC
Well said! And on that note, I'll have to re-think about my next set of wheels.
03-15-2014, 11:29 AM | #7 |
2739
Rep 6,734
I'm glad that helps. I definitely thought this through... Feel free to send me a PM if you need help on wheel specs in the future.
'23 X7
03-15-2014, 12:57 PM | #11 |
409
Rep 3,479
Drives: 19 M2C 6MT
Yes!!!
I need to shoot your car one day |
03-15-2014, 01:15 PM | #12 |
1053
Rep 3,206
Oh man!!! Look nicer than I thought! I hope you finally found a set you'll keep for a while LOL
Car looks beautiful!
e92 ///M3 |
03-15-2014, 01:18 PM | #13 |
192
Rep 3,633
Car looks good but these wheels looked better in pics IMO ( i.e. the ESS widebody).
Stepped lip 18s look way too small due to the center disk. For 18s I think reg. lip is a must. I even thought my stepped lip 19s looked small due to the 18" center disk.. I have Volk re30 in 18 on the car now so I like the 18" option better. Anyways, car still looks great! |
03-15-2014, 01:31 PM | #14 | |
2739
Rep 6,734
'23 X7
03-15-2014, 02:04 PM | #15 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
so much win!! come to the track on the 30th if you can.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
03-15-2014, 05:31 PM | #17 |
376
Rep 4,089
Drives: 21 X6MC
03-15-2014, 06:42 PM | #18 | |
2739
Rep 6,734
'23 X7
03-15-2014, 08:49 PM | #20 |
376
Rep 4,089
Drives: 21 X6MC
On the BBS website I noticed they have a different rivet design. Is that optional?
03-15-2014, 09:41 PM | #21 |
vvvvvvvvvvvvvv
333
Rep 2,305
