02-11-2014, 11:20 PM | #1 |
Ensign 1st Class
Rep 25
Tires - How wide can I go!
My 128i has 205/50R17's all around. With the stock suspension. There's a good 1 inch gap between the fender and the tire.
I want to lower the car about an inch all around (maybe a bit more in the front) at a later time. But for now I am looking into replacing all four with a wider and lower tire to firm up the handling and corning response and get rid of the mis-matched tires I have on it now. I cant afford new 18 inch rims and the tires so I'm looking at moving up to 225/45R17's all around. Keeping in mind the future lowering. Has anyone done a tire swap like this before? |
02-12-2014, 08:47 AM | #4 |
Ensign 1st Class
Rep 25
That's what I was thinking too. I've also heard that some wheel spacers would help with stance and stability. Not sure about the specs for stock/lowered though...
Thanks for the info. |
02-12-2014, 08:59 AM | #5 |
175
Rep 1,491
Hope this helps, Heres my 2009 128i sports package on H&R sport springs on stock 262 wheels. with 225 all around. no rubbing no wheel spacers.
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
02-12-2014, 07:36 PM | #6 |
Ensign 1st Class
Rep 25
Actually this helps a lot actually. It's a great reference since you provided all the specs...thanks kobe.
Are those Sport Springs or Super Sport's? The car looks lower than 1.5" What I'm trying to achieve is a perfectly symmetrical gap all the way around the tire. Just to illustrate I took the liberty of posting the image of your car with notes...(hope you don't mind my do that.) So I'm guessing that if I get 18's and lower it less that yours is, I should see a nice even gap around the outside of the tire. Again, thanks for the pics and info.
128i Automatic. Bone stock with tinted windows and 256 wheels.
02-12-2014, 07:37 PM | #7 |
Ensign 1st Class
Rep 25
That is a sweet ride though. Looks nice on the track.
02-12-2014, 09:08 PM | #8 |
210
Rep 2,233
Not trying to be mister-know-it-all but just putting on wider tires will not "firm up the handling". Wider tires will have taller sidewalls and since you are squeezing them onto stock wheels the wider sidewalls will roll more during hard cornering, and so you have gained nothing. My 128, before lowering, started with an M3 front swaybar and firmer rear subframe bushings. I'd start there.
02-13-2014, 12:31 PM | #9 | |
175
Rep 1,491
To the OP thanks man. Here are some tools that could help you. As for my ride height I'm on sport springs, just a tad lower then sports package. the H&R springs stance the car raked. There are other options that don't do that. I'm installing my Dinan camber plates so hopefully the rake look will not be as noticeable. I like it honestly though haha. http://www.1010tires.com/Tools/Tire-Size-Calculator http://www.1010tires.com/Tools/Wheel-Offset-Calculator
02-13-2014, 12:39 PM | #10 |
175
Rep 1,491
Here is another track day picture from the front. Same setup.
02-13-2014, 01:06 PM | #11 |
175
Rep 1,491
From what you said you when I input the stock base 128i tire spec, I think 205 it said with a 50 series sidewall, it's pretty close in sidewall height as too a 225/45/17. The link I will post states it's it's a tad shorter but still within specs. I don't think you will even notice it without busting out a measuring tape haha. That's what I am running 225/45/17.
http://www.1010tires.com/Tools/Tire-...0R17/225-45R17
02-13-2014, 01:29 PM | #12 | |
Ensign 1st Class
Rep 25
Nice tip on the sway bar and bushings though. I'm sure the car would be flatter in the turns and more stable without the "tail wagging" when whipping though the S curves. If I could find a cheap M sway bar out here in LA. I wouldn't mind getting one. I'm still figuring out what fits what in the BMW world. I didn't know a M3 sway bar fits a 2009 128i..?
02-13-2014, 01:36 PM | #13 | |
175
Rep 1,491
Sure does! Front control arms too. ECS has both OE Bmw and TRW kit (same quality) cheaper priced since bmw isn't stamped on it I think.
02-14-2014, 02:40 PM | #14 |
2045
Rep 25,989
225/45/17 can work with those wheels, although they're the widest recommended tire option that will fit on them.
VMR|Wheels | 714.442.7916 |
02-14-2014, 04:06 PM | #15 | |
Ensign 1st Class
Rep 25
02-15-2014, 12:16 PM | #16 |
Ensign 1st Class
Rep 25
OK, the tire sizes aside, I'm also looking into a rim size change. I have a 128i base model. Current rim I'm running is 256 5 spoke 17x7.5
I want to go up an inch or two but I'm not sure what rim sizes my car can handle. Anyone have a size chart with both stock suspension and lowered an inch to an inch and a half. (H&R touring cup or sport cup)?
02-15-2014, 12:45 PM | #17 | |
210
Rep 2,233
I switched to used 264s,no runflats, lowered on Eibach/Koni FSD with 135 front bumper and euro fog lights. |
02-15-2014, 12:51 PM | #18 |
Ensign 1st Class
Rep 25
Yeah I couldn't afford them because of the other mods I already had in mind but cant do them due to warranty issues so I'm looking for other ideas and the rims on it now are a wee bit small... So I figured it wouldn't hurt to do some research.
02-15-2014, 12:53 PM | #19 |
Ensign 1st Class
Rep 25
btw, how do you like the Eibach/Koni setup?
