01-30-2014, 12:36 PM | #1 |
2002
Rep 6,916
DetailersDomain.com - revives an 05 Porsche Carrera S
A customer brings in his new to him 05 Porsche Carrera S to bring it back to life from its former track duties. Customer wanted to stay within a budget so we concentrated removing the vinyl wrap, cleaner film on the bumper, the paint and headlights. Exterior - Wheels were prepped with Sonax Wheel Cleaner and cleaned up with various brushes - Tires were spritzed down with Adam’s All Purpose Cleaner and steamed - Wheel wells were cleaned up - Washed with Optimum No Rinse - Door jambs were cleaned up - Clayed - Dried - Tires dressed - Masking - Paint Measurement - Final Polish - Sonax Perfect Finish 4/6 - Paint Cleaner - Sonax Paint Cleaner - Last step - Sonax Polymer Net Shield - Inspection with Fenix, Brinkmann, and natural sunlight - Wheel wells were cleaned and protected - Rubber and Plastics Treated - Exterior windows and mirrors cleaned and sealed - Exhaust tips cleaned - Windows were auto scrubed, cleaned, and sealed - Headlight Restored - Headlight Coated Products used: Optimum No Rinse Stoner's Tarminator Auto Finesse Oblitarate Sonax Multi Star Sonax Full Effect Wheel Cleaner Uber Yellow Poly Clay Bar Sonax Perfect Finish Sonax Paint Cleaner Sonax Polymer Net Shield Adam's Super VRT Auto Finesse Crystal Glass Cleaner Auto Finesse Mercury Metal Polish Optimum Opti Lens Coating Tools used Uber Wool Wash Mitt Uber Quick Detail MF Towels Uber All Purpose MF Towels Rupes LHR75E Rupes BigFoot LHR 21ES Random Orbital Polisher Rupes BigFoot LHR 15ES Random Orbital Polisher Uber Orange Foam Pad Uber Green Foam Pad Defelsko Paint Meter Fenix TK35 Kranzle Pressure Washer Uber Foam Canon 2 Grit Guard Buckets with Caddies Adam's Firehose Nozzle Metro Air Force Blaster Before Clear Film and Vinyl removal using steam as well as using a heat gun here on the vinyl after the film was removed we tackled the headlights here they are a bit hazed up and cloudy Close up will show some sanding marks from possibly another detailer that attempted to fix the headlights improvements on the headlights 50/50 shot of the restoration using just the Sonax Perfect Finish 4/6 - 3 passes required on this one - Uber Orange Pad and Rupes LHR75E Prep was done inside with ONR Sonax Full Effect Wheel Cleaner in action Utilizing steam to clean up the mess Drying with an Uber Super Drying Microfiber Towel Using the Uber Yellow Poly Clay to clean remove contamination For the correction we use Sonax Perfect Finish 4/6 with an Uber Orange Pad and the Rupes - big improvements Rear fender before After (much improvement, the customer will be back to replace the fender guard film in the spring) Rear spoiler - before After - some very hard water spots were tough to remove may need some compounding on the next go around A quick wipe down on the motor/dressed with Adam's In and Out Exhaust tips were polished out with Auto Finesse Mercury Metal Polish Before After Inspection sticker clean up After shots Hope you enjoyed this one. Last edited by Detailers Domain; 01-30-2014 at 12:50 PM.. |
01-30-2014, 10:30 PM | #2 |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
I've said it before and I'll say it again: Terrific job.
And removing that vinyl wrap from the hood was one of the best things that could have been done.
02-22-2014, 02:22 PM | #3 |
172
Rep 2,347
Always amazing work guys!
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
02-24-2014, 03:53 AM | #6 |
But your honour it's my Affluenza I swear!
58
Rep 533
Nice!
135i M Sport DCT. BSM/Oyster/GP trim. FBO Cobb, Bilstein EDC coilovers, M3 bushings, PSS.
Knowledge of the Tapa Tapa Tapa street race start. |
Tags |
sonax 4/6 |
