01-03-2014, 12:42 PM | #1 |
342
Rep 1,805
13 E92 M3 on the scales, corner balance, percentages
Had the car corner balanced at west end the other day (AMAZING work btw). Was suprised the car (13 e92 m3 dct) weighed in at 3714 lbs w/ me in it.
I weighed about 176-178. Car had a half tank of gas and all fluids So car w/ no driver = 3538 (not bad for a fully loaded DCT) percentages w/ driver are: front 52.3% rear 47.7% left 50.2% right 49.8% they kill it over there...put on fresh tires, pads, corner balance alignment and went from 2:01:7 to 1:59:2 @ Buttonwillow C13 on Rs3 w/ kw cs 3way and stoptechs. Car felt phenomenal from the corner balance
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
01-03-2014, 07:37 PM | #2 | |
97
Rep 3,246
mods: track ready stuff
01-03-2014, 11:26 PM | #4 | |
342
Rep 1,805
Of course. Love sharing and learning from others info as well |
01-04-2014, 06:06 AM | #5 | |
2756
Rep 3,362
Thanks, Chuck
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
01-04-2014, 08:25 AM | #6 | |
342
Rep 1,805
Aftermarket dinan muffler saves a little. Not sure if the KW clubsports do or if the stop tech kit does as it's much bigger but it may. And apex 18s on rs3 wheels. |
01-04-2014, 09:56 AM | #7 |
ENTHUSIAST
135
Rep 2,097
Drives: 2010 Porsche Cayman
I'm pretty impressed with that weight. Especially since I have a manual coupe with few options.
"what I'm driving here...is an ending." Jeremy Clarkson
2010 Carrara White Porsche Cayman 6mt 2014 Whiteout Toyota GT-86 6mt(Sold 05/23/15) 2011 Alpine White BMW M3 6mt ZCP Coupe(forced retirement 06/06/14) 2008 Alpine White BMW 328i 6mt Coupe(retired 06/21/11) |
01-04-2014, 10:39 AM | #8 |
342
Rep 1,805
Made me think a manual coupe with basically no options, the no leather manual seats could definitely be under 3500. Especially with some light mods then definitely would be
01-04-2014, 10:54 AM | #9 |
663
Rep 1,424
~3500 sounds about right. For what it is worth I have a track buddy with one of the most modified e92 m3s. He claims the biggest jump in performance was from removing weight. He is below 3250 with 1/4 tank gas no driver......and that car/driver moves!!
01-04-2014, 04:50 PM | #10 |
Retired Curmudgeon
3001
Rep 4,088
That's sick. When I raced in I-stock, my E36M3 had to be 3175 lbs WITHOUT driver!
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-04-2014, 06:13 PM | #11 |
1581
Rep 8,077
Drives: 11 E90 M3 Individual
So did they use hub stands when doing the corner balancing?
The really good places do the corner balancing and alignment on hub stands, not tires. And that will take off about 200lbs from the actual curb weight. But a dinan muffler and Apex wheels will save about 80 lbs.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-05-2014, 04:25 AM | #13 | |
2512
Rep 4,381
01-05-2014, 10:47 PM | #18 |
1581
Rep 8,077
Dang...I'm genuinely surprised then. Now I'm curious to see how much mine weighs!
01-05-2014, 11:41 PM | #19 |
34
Rep 898
Once I put my roll bar and harness in, I'll get the RS corner balanced. I'm curious how close to 3,000lbs it weigh since I took off the OEM exhaust and saved 50lbs+ off the rear.
01-06-2014, 05:57 AM | #20 |
2756
Rep 3,362
By fully loaded do you mean sunroof and DCT?
Current Stable:
01-06-2014, 09:56 AM | #21 |
11818
Rep 23,187
had every option beside dct i believe. back half was then stripped out.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
01-06-2014, 10:01 AM | #22 |
115
Rep 1,470
which exhaust did you install? how loud is it?
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
