10-31-2007, 02:43 AM | #1 |
105
Rep 585
German AUTOZEITUNG tests M3 against C63
The german AUTOZEITUNG from today has tested the BMW M3 (E92coupe) against the Mercedes C63.
The M3 is clearly better on track (handling, weight and specially the much better brakes) but looses overall mostly because of its disadvantage of 2-doors against 4-doors...without this it would be an very close race Greets Uli_HH |
10-31-2007, 04:05 AM | #5 |
196
Rep 657
LoL, 15.3 is almost M5 performance but 16.1 is not bad either
C63 is likely going to win most redlight races agains the M3. I wonder how much faster M3 was around Autozeitung's testtrack than C63. |
10-31-2007, 04:11 AM | #6 | |
205
Rep 461
do you confirm that still the 8.03 on the Ring is provisional?and we still don't know if the Cup tires were used?I am sure that you will have the definitive lap time before that Sport Auto will be available. Am I right?? many thanks |
10-31-2007, 06:40 AM | #10 | |
Reincarnated
245
Rep 4,227
This is the same exact lame conclusion that I believe CAR magazine came to. Why pit them against each other then and use the number of doors as the defining criteria?
10-31-2007, 07:31 AM | #11 |
1118
Rep 8,017
The reason they pit both together is to full space in the magazine and of course help sales. If they were to wait until BMW had the M3 saloon out for comparison then that would be to late for some of the buyers who have their name do for one or the other now.
You have to read between the lines and ignore the different body types, if either car appeals based on everything else then go for that and but the other. The only reason why I wouldn't have the C63 is the automatic box, there is always that delay between throttle being pressed and gear dropping down and car going forward, I hate it and will never warm to torque converters. Thank god the M3 is getting a dual clutch manual box instead. |
10-31-2007, 10:59 AM | #12 | |
105
Rep 585
No...both were on 18" (M3 Michelin PS2 / C63 Pirelli P Zero)
Lets hope that the coming M-DCT make the difference and the M3 eats the C63 Greets Uli_HH |
10-31-2007, 01:26 PM | #14 |
Moderator / European Editor
1540
Rep 6,754
Braking distance:
M3: 35.7m (cold) - 35.0m (warm) C63: 36.2m (cold) - 35.4m (warm) 0-100 kph | 0-200 kph: M3: 5.1s | 16.1s C63: 4.6s | 15.3s laptimes: M3: 1.39,0 C63: 1.40,3 slalom: M3: 62.1 Kph C63: 59.7 kph Best regards, south |
10-31-2007, 01:39 PM | #15 |
26
Rep 580
That 0-100 time for the M3 is a little slow. Either they had traction problems or the car was a little off. I wonder what the AZ 0-100 time was for the E46 M3.
10-31-2007, 05:12 PM | #17 | |
205
Rep 461
10-31-2007, 05:47 PM | #18 | |
205
Rep 461
pls check below: 8. Porsche 996 Turbo S 1:38.5 Autozeitung 9. Lamborghini Gallardo Spyder 1:39.0 Autozeitung 10. Chevrolet Corvette Z06 1:39.4 Autozeitung 11. Porsche 997 Carrera S 1:39.8 Autozeitung 12. Audi R8 1:39.8 Autozeitung 13. Dodge Viper SRT-10 1:39.9 Autozeitung 14. BMW M6 1:40.0 Autozeitung 15. BMW M3 (E92) 1:40.1 Autozeitung with Cup tires!! |
11-01-2007, 05:23 AM | #19 | |
1540
Rep 6,754
11-01-2007, 06:46 AM | #20 |
11
Rep 79
Very strange time because i know 1:40.1 for M3 with Cup+
http://www.fastestlaps.com/index.php...=46f388d80d375 |
11-01-2007, 08:08 AM | #22 |
Moderator
7515
Rep 19,368
I am confused to which point in this thread that you are addressing with this statement. As a purely general statement I'd disagree, since the wheel size is independent of sidewall thickness and wheel/tire width, which are typically more important to handling (not to mention tread and rubber compound).
