12-19-2013, 08:20 AM | #1 |
29
Rep 243
Fuse Box 135i
Was looking at the fuse box to check the fuses for the ac and was wondering if any tool is needed to pull the fuses out. The space seems really tight. Once you put your hand in there you can hardly see which fuse is being pulled out. Anyone using any tools (pliers etc).
12-19-2013, 09:26 AM | #3 |
European Editor
10594
Rep 22,992
I used some needle nose pliers with "teeth" on the ends. These pliers are made by Hazet, but I am sure most of the tool truck companies make something simular. The teeth grab onto the raised edges of the fuse and it pulls out easily. You can also buy one of those cheap American fuse kits that have a "fuse puller" that comes with the kit.
Hazet tool #666-10 135i fuse box... BMW has put a fuse puller(red/pink in color) mounted right on the fuse box. Look almost dead center of this photo, and to the left of center. See the fuse puller? Just above the wiring harness. more 135i fuse box pics here.... http://www.1addicts.com/forums/showp...&postcount=157
12-19-2013, 11:33 AM | #5 | |
European Editor
10594
Rep 22,992
Dack
12-19-2013, 11:36 AM | #6 |
Rep 29
Those red "clippers" in Dackelone's last photo, on the bottom left, is ment to clip onto the fuses and you pull them out with that.
'08 135i - Ground Control Coil Overs - Alpina Flash Tune- Front Lip- Rear Diffuser- Intakes- FMIC- More to come soon!
