11-29-2013, 06:40 AM | #1 |
886
Rep 9,097
For Sale
-CIC (new navigation) with built in DAB plus from 2011 car - BMW applications are free on the HU (if installed with Combox) - come with 2014 maps - 7 digit post code search £750 without combox It can be fitted and coded to your car if needed. Thanks.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play Last edited by makkan00; 12-15-2013 at 08:29 AM.. |
12-12-2013, 03:55 AM | #2 |
15
Rep 135
Hi,
Looking to upgrade the CCC system to the CIC, However I currently have TV (Freeview), DAB, Bluetooth, BMW Assist/Connected Drive, & Navi. If I was to do the exact replacement with what I have at the moment, added bluetooth Audio streaming and the USB port under the armrest (my CCC system didnt come with this) how much would i looking for this, the price should include fitting. Also are there any modules that can be salvaged from the CCC system or would it all require new bits? Many Thanks
12-12-2013, 12:50 PM | #3 | |
886
Rep 9,097
If you have bmw assist and connected drive (paid), then I'd suggest you to keep the TCU box in your car as IMEI of it is registered against your car on bmw data base. Having said that you cannot have combox (BT streaming and 6FL/ usb connectivity). As you will loose BMW connected drive. To summaries, just upgrade your CCC to CIC without combox in your car. Cost: CIC kit CIC controller trim for M3 approx £300-350 (one was on ebay recently and worth of sending the seller to see if its still available) Emulator (£75-80) Cable from CIC to CID £38 USB socket with usb hub + cable + glove box skin £100 Most loop terminator £20 Fitting cost (feel free to pm) DAB antenna cable £10 PS: Your DAB module become redundant and you can sell it. But you will require to keep your TV module to have freeview.
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
12-16-2013, 05:17 AM | #4 |
15
Rep 135
Forgot to mention that I also have a CD Changer and to be able to keep the CD Changer and add USB too.
Why can I not have the combox (bluetooth/USB) and keep connected drive? The version i have is the paid one, with bmw online. Ideally I want the bmw apps to work with the CIC too.
12-16-2013, 06:14 AM | #5 | |
886
Rep 9,097
Re: combox Your current TCU has IMEI number and with which it communicates with the BMW server to have BMW connected drive and 'send a link' to CCC. When you retrofit combox, it will be 'unofficial' retrofit as BMW does not allow such kind of retrofits, and they are not going to register the IMEI of combox against your car. You will still have connected drive and BMW applications, but it will work by thethering the internet via your phone. In that case, you will loose the ability of 'send a link/ message to your CCC' and remote application for your car (if there is any for CCC). HTH.
12-16-2013, 07:39 AM | #6 | |
15
Rep 135
Could you give me the part number for the combox? If BMW agreed this, then could I get the bluetooth audio streaming? Many Thanks
12-16-2013, 10:26 AM | #7 | |
886
Rep 9,097
Combox was introduced in late 2012, so the cars manufactured afterwards can buy it from bmw and then get it retrofitted. Again, just a media combox with 6FL is approx £900 fitted by a dealer (example). If you want to retain 'send to car feature' then you should retain your TCU and just upgrade your CCC to CIC. Lastly, no disappointment, but this unit is SOLD now pending the final payment and collection. Thanks.
12-17-2013, 10:18 AM | #9 |
886
Rep 9,097
I am based in Essex now.
I still remember that we had this chat when I had the other CIC for sale few months ago. If you are happy to travel to the Essex, then we can catch up.
12-18-2013, 06:08 AM | #11 |
886
Rep 9,097
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play Last edited by makkan00; 12-18-2013 at 11:23 AM.. |
12-18-2013, 11:23 AM | #13 |
886
Rep 9,097
I'm really sorry. I answered that in the office and did not pay attention what I was typing. Just corrected it. Apologies.
12-19-2013, 07:54 AM | #14 |
12
Rep 126
rumelk, like makkan said you can't have the combox if you want to keep your BMW Assist subscription up and running.
To get a USB port, you could install a MULF module instead of the combox, which will work alongside the TCU which is responsible for BMW Assist. Note - the MULF won't give you bluetooth streaming or apps, etc. it will only give you a USB port. |
12-19-2013, 01:11 PM | #15 | |
886
Rep 9,097
04-11-2014, 07:33 AM | #16 | |
Rep 1
Hi! What kind of Dab antenna do you use here? |
04-11-2014, 02:52 PM | #17 | ||
886
Rep 9,097
I prefer using oem dab antenna and if its not possible, then aftermarket one.
