11-19-2013, 04:48 PM | #1 |
Rep 2
E87 130i Questions
Hello I'm currently researching the E87 130i and can't decide between an auto or a manual. I'm curious as to how much the performance is dulled due to the torque converter. Can the tires still be made to chirp with the auto while riding the transmission up to about 1500 rpm? I ask because my brother in law has an E60 530i with the 200kw engine and the M-sport pack so its over tired IMO, and it just goes off the line without fuss or a hint of the traction control system being needed. Also how is the durability of the automatic?
Thanks for the help. |
11-20-2013, 12:47 AM | #2 |
Rep 183
I would suggest you get the manual if you are comfortable with stick shift.
The driving enjoyment would be dulled by an auto transmission no doubt.
2008 BMW M3 | 6MT | OEM Exhaust Mod | Black Grilles | |
11-20-2013, 05:57 PM | #5 |
Rep 72
Definitely manual..
ok i know its a whole different kettle of fish, but i've been considering moving to a E90 335i (4 door) which i've found only autos. And while its very good still doesn't compare to manual. (also the torque curve is massively different so i'd assume the 335i auto will feel a lot better than 130i auto) 130i's arent that torquey. 130i manuals shift very nicely, the clutch is a little soft at first but you get use to it. (CDV delete helps this slightly) |
11-20-2013, 07:36 PM | #6 | |
371
Rep 339
Drives: 2022 G80 M3 Competition xDrive
11-20-2013, 07:50 PM | #7 |
Rep 72
oh you have both yeah i kind of felt that too.
I did feel the 335i to be much more stable cornering, and had a more neutral poise, where the 130i was skittish, very slightly front heavier. Power wise.. because of the relatively constant torque delivery of both, it honestly didn't feel that much more exciting.. (but maybe a tune will fix that) but could well be the auto vs manual. although i did think the 335i exhaust note was nicer.. had a more raspy noise.. (i have stock on my 130i) anyway off topic.. MANUAL! |
11-20-2013, 09:23 PM | #8 |
Rep 2
How much does a new clutch installed cost? I ask because if I choose a manual I'd be learning to drive manual in that car hence my dilemma between the auto and the manual.
11-20-2013, 10:29 PM | #9 | |
126
Rep 3,099
i can tell the missus' 135i is much heavier up front than my N52 haha the short wheel base will make all 1ers feel a little less stable than the 3ers though. not sure on the 335 exhaust, but the 135i definitely needs opening up with the turbos muffling, it's almost silent compared to my 130 and yeah, all the N54 powered cars REALLY need a tune to feel more alive! - i find it harder to speed in the 135i, cos you have to put your foot down then a slight pause THEN acceleration.. the 130i you put your foot down then go 'well... i'm here NOW...' hahaha anyway 130i manual may be a LITTLE quicker than the auto, due to power losses etc. 135/335, the auto is much faster, due to load keeping boost between shifts etc still, 6MT all the way 100%!! |
11-20-2013, 10:32 PM | #10 |
38
Rep 839
You wont do any damage to the clutch.
Unless you drive like a complete and noob, similar to how you see them in movies when trying to learn "stick"
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec |
11-21-2013, 07:48 PM | #11 |
171
Rep 2,682
Yeah don't worry about the clutch. I pretty much learnt how to drive manual in my 135 earlier this year. Even toon it to the drag strip 3 weeks after picking it up
Clutch still holding well! (Touch wood)
11-25-2013, 08:22 AM | #12 |
36
Rep 283
the 130i manual is lovely. just got it. and my first manual car at that!! easy to learn on as long u are patient and careful.
difficulty being the hill hold assist that you can't turn off. may bugger your ability to do hill starts. otherwise. love the car to bits. probs one of the best NAs around. bar the s65. |
