11-17-2013, 01:45 PM | #1 |
25
Rep 387
Help on my 2008 M3 E90
So this all started with my passenger side heated seat not working.
I took it upon myself just like most of us would have done by checking to see if a fuse was blown. That was not the case! I didn't disconnect the battery, which was my first mistake. I started pulling all the fuses to see if any was blown. When i was done i started my car. To my surprise a few warning lights came on! Left back break light off- Light is not blown, i checked Right back ligh is not on, i check light, its not blown Left front light on but angel light not on Right front angel light on but regular lights not on High beam light are not on when i turn them on inside lights on the window buttons are not working So far this is what i did I check all the fuses to make sure they were all put back the same way. TG i took a picture. I disconnected the battery for 30mnts still no luck I brought it to my buddy to see if he could clear any codes. None were found I figure before i bring it to the dealer and get rape i would post on here maybe someone could help any suggestions Thank you in advance for your help |
