11-15-2013, 03:36 AM | #1 |
e36s54, e70x5d
151
Rep 1,723
KW Clubsport 3-Way for F10M5
These might be a bit overkill ... but I did see some crazie F10M5 track stars on here.
http://www.kw-store.com/products/kw-...t-kit-111.html It looks nice ... with helper springs and all Does anyone know the spring type/rate? Do they mean 3-way = 1. Low Speed Compression 2. High Speed Compression 3. Low/High Speed Rebound? Also, does Ohlins have a R&T kit for this car like they have for e90m3? |
11-17-2013, 11:05 AM | #2 |
Route Runner
137
Rep 661
At $6300.......i would think theyre overkill!
16 SMB M6 Gran Coupe
16 BS X6 X-line (wife's truck) 13 AW M5 (sold) 04 Honda Pilot (everyday car) |
11-17-2013, 01:30 PM | #3 |
2871
Rep 11,374
We have the Clubsports installed on the iND F10 M5. Surprisingly the kit is very comfortable on the street and very forgiving on the track.
11-17-2013, 03:42 PM | #4 | |
e36s54, e70x5d
151
Rep 1,723
Do you happen to know the spring type and the spring rates and what the 3-way adjusts? |
12-18-2013, 06:29 PM | #5 | |
Perennial PFC
338
Rep 1,275
I talked to a KW rep on the phone today and he wasn't up to speed on exactly how their part is configured for the F10 M5. The EDC needs to be disabled on our F10 model, but it is NOT included as part of the Clubsport package for some reason, and costs an additional $490! The identical EDC delete module is available with the V3 coilovers for an additional $300, and he wasn't able to explain the cost difference....... Said it was just the price structure that KW has set for the shock packages...... So, they charge $6,348.99 for the Clubsport shocks, and an extra $490 for the EDC delete module, and $3,249.99 for the V3 set with the EDC module an additional $300! Very strange. The springs on the V3 are progressive while the Clubsport are a linear rate more oriented to track use. He didn't know spring rates on either set. He also said that changing the V3 springs to a linear rate spring would void the warranty. IND has said on this forum that the Clubsport on their M5 felt "very comfortable on the street". I'd like to feel that comfort before I plunk down $7K for suspension. I talked to Luke at Tire Rack and his thinking is that the Clubsport is very, very stiff for street use and he wouldn't recommend it for street use. But, that opinion is based on previous Clubsport coilovers on other models of cars. More research needed before purchase for me. |
12-19-2013, 02:36 AM | #6 |
e36s54, e70x5d
151
Rep 1,723
The added adjustability of the Clubsports seems like the only positive in this case. But really ....the 2-way adjustability of the V3s is enough for any amateur ...to even a pro.
If they stiffened the springs anymore (over the V3 springs) its not going to be as comfortable or compliant. I am very happy with the V3s on my F10M5 so far. They seem very well suited to the weight of this car and I honestly think that this setup is pretty much the limit for the comfort vs. handling compromise. You truly get the best of both worlds w the V3s ....comfort when you just want to get around ....and stability when you just want to get on it. F10M5 = "The luxurious beast" |
12-19-2013, 07:42 AM | #7 |
Perennial PFC
338
Rep 1,275
Somehow I'd missed that you already have the V3 package on your car. Thanks for the report and for my use I think the V3 will be more than adequate for the few trackdays I'll do each year. One question though, for the F10 M5 has the rebound adjustment been moved from the top of the piston rod? We can't access that once the shock is mounted. Thanks for your input.
12-23-2013, 09:49 AM | #8 | |
e36s54, e70x5d
151
Rep 1,723
However, the rears are covered by the trunk liner. You can have access holes cut or spend 10 minutes removing and reinstalling the trunk side inner liners everytime you want to adjust the rears. You would only do that everytime you go to the track and once or twice when you initially have the kit installed and you know what settings you prefer. |
12-24-2013, 09:41 AM | #9 | |
Perennial PFC
338
Rep 1,275
12-25-2013, 03:49 PM | #10 | |
e36s54, e70x5d
151
Rep 1,723
AFAIK, the only downside to not installing the KW EDC modules is a warning light on the dash....at least that was the case with the e92m3. However, I would not put it past the new generation of DSC nannies to make life difficult if the 18 computers cant agree on a missing signal. |
12-26-2013, 12:38 AM | #11 | ||
Catch me if you can
63
Rep 679
Liners
12-26-2013, 09:48 AM | #12 |
Perennial PFC
338
Rep 1,275
Yeah, I think the complicated computer system BMW has developed must be very difficult to deal with. Hence no real programmable engine tune available yet, and perhaps never. With that situation BMW will be able to set a high dollar value for HP upgrade options when they sell new cars in the future.
12-26-2013, 12:57 PM | #13 |
e36s54, e70x5d
151
Rep 1,723
Good question -- I have not attempted this yet, since I feel my rear setup is ideal right now.
There might be a set of BMW instructions that deals with removing the rear liners to get to a certain unit for repair or replacement.... but usually it's a simple process of removing a few push-n-spread plastic buttons that hold the liners to the body interior. Just takes some investigating and prying with those plastic interior removal tools. |
12-26-2013, 04:32 PM | #14 |
2871
Rep 11,374
Here are some closeup shots of the Clubsport kit-
Here are some shots. Back seat and rear rear parcel shelf need to be removed along with trunk liner for the EDC resistor install.
12-26-2013, 08:55 PM | #15 | |
Catch me if you can
63
Rep 679
Easy..
No need to take out rear deck. |
12-27-2013, 09:50 PM | #16 | |
e36s54, e70x5d
151
Rep 1,723
Can you reach the KW top adjustment with an Allen wrench or bit driver? |
12-27-2013, 10:01 PM | #17 |
e36s54, e70x5d
151
Rep 1,723
Nate, thanks for the pics.
Nice setup. I like how there are helper springs front and rear. How about some technical info on these. Spring rates? Spring type? 3-way = ? |
12-27-2013, 11:55 PM | #18 | ||
Catch me if you can
63
Rep 679
Yes.
12-29-2013, 10:47 PM | #21 |
206
Rep 7,298
12-30-2013, 11:11 AM | #22 |
e36s54, e70x5d
151
Rep 1,723
