11-11-2013, 11:09 AM | #1 |
24
Rep 387
OEM Projector Lense
Hello! I am new to this forum and have had my 135i for less than a month!
In my previous car ('08 Honda Civic Si), I had retrofitted Honda S2000 projectors with clear lenses in the headlight housing... This produced a beam pattern similar to what is shown below.. *Notice the sharp and colourful cuttoff of the beam pattern My 135i already has the AHL Xenons, but the stock cutoff is leaving me wanting for more. Has anyone modified the OEM AHL Xenon projectors by swapping out the freshnal (opaque) lense with a clear lense? More information about this if you are not familiar with Retrofitting projectors...: http://customlightz.com/?p=p_157&sName=clear-lenses Thanks! Roll |
11-11-2013, 11:12 AM | #2 |
Resident Tamed Racing Driver
298
Rep 4,697
Lightwerkz has done a few. After my last retrofit project with them though, I don't think I'm interested in buying any more of their products. Factory xenons are good enough that they aren't worth the headache.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
11-11-2013, 11:32 AM | #3 | |
24
Rep 387
I am not really that interested in upgrading/changing the Angel Eyes on the headlights like most people seem to be... I am more interested in either a clear swap to improve the stock output of the stock projectors and give a slight colourful cutoff...or to even see if a pair of Lexus RX-330 projectors (With AFS...which i believe is the same idea as the AHL for BMW) can be retrofitted instead of utilizing the stock OEM projectors. The RX330 projectors are pretty widely known to be really good projectors for the price. I miss having this type of WIDE beam too! |
11-11-2013, 01:16 PM | #4 | |
298
Rep 4,697
I miss bi-xenons with halogen highs. My fiance's ZHP with fresh covers(E46 lens covers are a factory replacement part) and 85w rally halogen highs has amazing light output.
11-11-2013, 03:37 PM | #5 |
1558
Rep 3,239
Have fun taking apart the headlight lens. Once you do it is easy to pull off the shroud and replace the projector lens. I would recommend ZKW clear lens.
Edit: or do what I did and retrofit FX-R bi-xenons instead....
2012 BMW 128i 6MT Deep Sea Blue Metallic
11-12-2013, 01:56 PM | #6 | |
24
Rep 387
With that said, if you have a stock AHL headlight with your car...does anyone know if it is possible to retro some Lexus RX-330 AFS projectors (Lexus version of AFL I believe) and get the AHL system to work with the new projectors? |
11-12-2013, 01:57 PM | #7 | |
24
Rep 387
BUT... i want that WIDE beam and killer cutoff! so who knows |
11-12-2013, 02:31 PM | #8 |
1558
Rep 3,239
I will post a picture later. But why not do this:
1.buy halogen headlights 2. Retrofit 3. ???? 4. Profit (Sell 135 headlights after retrofit lol)
11-12-2013, 02:36 PM | #9 | ||
1558
Rep 3,239
I also like hidplanet and love buying from trs
11-14-2013, 03:31 PM | #10 |
24
Rep 387
Here's the thread..
http://www.hidplanet.com/forums/show...please-help!!! Interesting info in here. The last post (on page 6) shows pictures of the projector housing... the original poster basically gives up due to the complexity of the AHL. |
11-14-2013, 03:32 PM | #11 | |
24
Rep 387
If I did this...any ideas if the car will freak out because it thinks the AHL system is malfunctioning due to it being missing? I'm used to coming from a Honda where stuff was simple and didnt have to worry about this kinda stuff! |
11-18-2013, 10:35 AM | #12 |
24
Rep 387
11-18-2013, 10:46 AM | #13 |
European Editor
10607
Rep 22,992
I am not a fan of those "colorful" rainbow like cutoffs. Reminds me Audi's headlights. yuk
I like your second pic much better... but your headlighst are aimed WAY too high! lol Why not find someone who can code your OE lights to the Euro AHL specs. Brighter on high beams and wider pattern/spread at low speeds an at over 100 kph the headlights move to the straight ahead position. AHL2 EU headlight Coding... http://www.1addicts.com/forums/showthread.php?t=843765 While your at it you can also have the AE coded to run brighter without changing the bulbs!
11-18-2013, 11:06 AM | #14 | |
24
Rep 387
Funny that you mention the colourful cutoff thing... I've noticed other BMWs have sharp cutoffs and colourful cutoffs So i do not think its something that is just an Audi thing...I have noticed that Acura, Range Rover, and Cadillac also tend to have colourful cutoffs as well. I do not think recoding will help create a sharper cutoff... The lack of sharpness is due to the lense of the projector being Freshnal (semi hazy) instead of clear. Also, I am more concerned with cutoff being colourful rather than changing out to a higher Kelvin rating bulb. I dont mind stock 4300k bulbs! |
11-18-2013, 08:58 PM | #15 | |
1558
Rep 3,239
Been meaning to post my build thread but have been busy: http://www.1addicts.com/forums/showthread.php?t=852426 The only thing I would do different was use a heat gun to take the headlights lens apart, which I did not have at the time. No issues since a week after I built them, which were caused by my mis handling originally.
11-19-2013, 10:42 AM | #16 | |
24
Rep 387
Also, I believe TLs are BiXenon... they might be a little harder to retro though (bigger projector I think?) Here is a Hidplanet thread ---> http://www.hidplanet.com/forums/show...tor-What-is-it |
11-19-2013, 04:25 PM | #17 |
1558
Rep 3,239
Then I am mistaken. It was the TSX-R's that I was thinking of.
FYI: Our headlights have plenty of room for TL's. The back cap will need modification though.
12-11-2013, 06:49 PM | #18 |
24
Rep 387
So i've been analyzing the beams at night... and i feel like they are aimed a bit low? anyone else notice this? i know they are supposed to be Auto Headlight Leveling.... but maybe I'm just used to them being higher?
The inner lamps (the halogen) definately help...but i do wish the low beams were a tad bit higher. |
12-12-2013, 11:21 AM | #20 |
24
Rep 387
12-12-2013, 11:33 AM | #21 |
298
Rep 4,697
Same process.
