11-09-2013, 11:33 AM | #1 |
111
Rep 746
How to load nav update in 2008 M3 after downloading?
What are the steps?
My car doesn't recognize the DVD when I put it in...thx guys. Last edited by tony093; 11-09-2013 at 11:57 AM.. |
11-09-2013, 12:38 PM | #2 |
Stop the hate, get a V8
3851
Rep 8,625
Might help us if you explain how you burned the DVD.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
11-09-2013, 03:09 PM | #3 |
197
Rep 710
If car isn't recognizing the DVD then you have a bad DVD build. Car should see you put a new DVD in and tell you to turn off car for X amount of minutes and then turn it back on while in open view of the sky.
11-09-2013, 06:18 PM | #4 |
58
Rep 535
Yep, that's what happened with mine, worked perfectly. I burned the ISO image to a DVD using disk utility on my Mac.
11-09-2013, 10:25 PM | #5 |
111
Rep 746
What do you mean by a bad DVD build? How did you correct the issue?
11-09-2013, 10:26 PM | #6 |
111
Rep 746
11-09-2013, 10:35 PM | #7 |
111
Rep 746
11-09-2013, 11:24 PM | #8 | ||
58
Rep 535
When you download everything, you will have 3 zip files. Extract them and then burn one of them to a DVD (I used part 1, not sure if it matters). Then put that DVD in your car and try it out. You do not need to burn all 3 to a DVD, just one of them.
12-08-2013, 02:59 PM | #9 |
15
Rep 135
Do you have the CCC or CIC sat nav, as im sure the 08 came with CCC which uses a single DVD, the latest maps (according to bmw) are the 2009 maps, no further update has been done for the CCC units.
12-08-2013, 08:31 PM | #10 |
197
Rep 710
Dfjawas and I both have the CCC unit (old skool) nav setup. The latest maps are the 2014 maps actually which is now available for download on this forum for both CCC and the CIC units.
12-09-2013, 08:36 AM | #11 |
15
Rep 135
could you shed some light as to where those download links are for the CCC 2014 maps!
12-09-2013, 08:53 AM | #12 |
197
Rep 710
Here you go: http://www.m3post.com/forums/showthread.php?t=901284
