10-20-2007, 10:09 PM | #1 |
More than you can afford pal....ferrari
181
Rep 1,471
quick question
i got a question about painting grills. i saw that some people sand and just spray painted them. i do not understand the sanding part?? do i sand the chrome and hoow much should i sand them?? help ???
10-20-2007, 11:44 PM | #2 |
My favorite sign.
169
Rep 4,333
I don't think you need to sand the "chrome" grill. Just prime it and paint it. You may need 2 coats possibly 3, but it will look fine when you are done.
10-20-2007, 11:56 PM | #3 |
61
Rep 1,210
The reason you sand it is so the primer sticks better, then the paint sticks better to the primered surface. Its less likely to peel/chip/come off also adding a layer of clear coat helps as well.
10-21-2007, 09:52 AM | #4 |
My favorite sign.
169
Rep 4,333
Isn't the chrome plastic tho? I don't think sanding it is gonna do a whole lot...and if you get a good mp primer it should stick easily to about anything.
10-21-2007, 03:21 PM | #6 |
My favorite sign.
169
Rep 4,333
I think you're putting way to much thought into this. You can do it a number of ways. If you want it be quick and easy, hit it with some spray primer, and then spray paint it. You could use a paint brush if you want, but it's not that big of deal...
10-21-2007, 06:40 PM | #7 |
181
Rep 1,471
lol thanx man i i did it. i was just a little paranoid bc i didnt want to fuck up the stock grills. but i just said fuck it if i mess up ill just buy new ones. but it turned out nicely thanx again
10-22-2007, 10:22 AM | #8 |
2070
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
When I painted my headlights on my old car I didn't sand the 'chrome' plastic, I just primed and used Engine spray paint (heat resistant) and then I clear coated it and it stayed in perfect shape for the 5 years I had it done (although it was inside a silicone sealed housing...)
I wouldn't sand it unless you have problems with flaking or chipping and then the second time you can try the sanding and see if that helps.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
