10-04-2013, 08:47 PM | #1 |
58
Rep 200
SIB 12 09 12 software update for stalling, idle and surging rocks but theres more...
Could not be happier with this update released in April 2013. Car is totally predictable and linear when accelerating from a stop now. It's too soon for a full a report but I have noticed other things that have now changed from the update as well:
- When hitting my blinker half way for quick lane changes it only blinks once now and before the update, it blinked 3-4 times before self cancelling. - I now have DRL? Prior to the update when i turned the lites off they were completely off. Now I have angel eyes in the off position. Does anyone know the full list of things this update accomplishes? Obviously more than just fixing stalling and surging.....
2011 AW 135i
10-04-2013, 09:03 PM | #2 |
2394
Rep 6,083
They somehow erased the setting in your turn signal - maybe they did the battery recall? Look in your owner's manual under "personal profile." In my manual (also a 2011), the personal profile is described on page 18 of the primary manual, and it points to page 57 for the turn signal setting.
10-05-2013, 09:25 AM | #4 |
1837
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Those are also settable from the upper left-side stalk on the steering column if you don't have iDrive.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
10-07-2013, 08:08 AM | #5 |
58
Rep 200
Huh, Thanks guys...I should have thought of that. I kinda like the DRL's.
Are they prone to blowing out like house lite bulbs if left on all the time? I'll turn them back off if it will prolong their life otherwise I'll keep them on.. Do you guys have yours activated??
2011 AW 135i
10-07-2013, 09:06 PM | #6 |
The Crowing
111
Rep 2,005
I had them on all the time but when I made my angel eyes blue I now turn them off depending on where I'm driving. Don't want a ticket.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
10-08-2013, 02:43 PM | #7 |
Rep 24
What is the most effective method to get the techs to make sure the car has the most up to date software?
My car currently fluctuates RPM at idle and is a little unpredictable in drive. I simply stated my issues as they are and I am taking the car in tomorrow for a state inspection. |
10-08-2013, 03:52 PM | #8 | |
2394
Rep 6,083
<OO (llll)(llll) OO>
10-09-2013, 06:11 PM | #9 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
I know the update also changes the direction in which direction the heated seat LED's light up lol
10-15-2013, 08:51 PM | #10 |
Rep 11
Just wanted to thank you for posting this, OP. I was having the same issue and when I was in last year I brought it up but the tech "was not able to duplicate this condition." After seeing this post, made an appointment this weekend, told them to do the software update, and the car is running better than ever.
10-16-2013, 10:04 AM | #11 |
88
Rep 524
Is there a list somewhere that shows when they switched putting a certain software release on the production line cars? I took delivery around when this SIB came out, but they could have had it in production before. Thoughts?
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
10-16-2013, 10:22 AM | #12 | |
European Editor
10594
Rep 22,992
But to answer your question normally the car's leaving out of the factory have an older SW level than what is available at the dealership. I do not know why that is. IF you are having idle issues it is best to talk to your local service dept and or tech. Maybe they know of a fix. You can also make a video to give them, that way they know your not making it up.
11-07-2013, 07:43 PM | #13 | |
119
Rep 264
2019 X3
2011 135i Alpine White DCT N55 All Stock Built on 10/10 Proud owner since 12/12. |
11-08-2013, 04:18 AM | #14 | |
11
Rep 93
Thank you ! |
11-08-2013, 06:39 AM | #15 | |
460
Rep 4,531
At lights it seems like my revs are searching a bit. The car isn't jumping in revs or anything...but just minimal +-500 rpm increases that you can barely see on that tach, but you can feel in the seat |
11-08-2013, 11:06 AM | #16 | |
European Editor
10594
Rep 22,992
The SIB is for N55 motors(135i). I do not know what the latest SW version is for the N52/N51. ? Maybe try posting in the 128i section (128i Engine (N52), Exhaust and Drivetrain Modifications).
11-08-2013, 11:42 AM | #17 |
521
Rep 1,502
I recently took my car in for the battery cable recall and some engine hesitation issue.
They mentioned they updated the software...Now my car is much smoother, but much slower. it does NOT pull the same. Butt dyno. I can't break the rear wheels free in first gear anymore. 50 degree temp and A/S tires. The pilot a/s plus would break free in 1st and 2nd before the update Not happy I am not happy
miiipilot
'24 M2 Brooklyn Grey, 6mt, Bi-Color, Black M-Color seats, '16 MG M2, DCT, Exec. Took Delivery 4/30/16 (Sold) |
11-08-2013, 11:48 AM | #18 |
Rep 101
I had a friend who had this update and we both can tell they neutered the car.
The car is smoother yes but seems lacking in power now compared to before update. Compared to my car, mine is so much more responsive and appears to have much more torque earlier on in the power band |
11-08-2013, 12:20 PM | #19 | |
460
Rep 4,531
I'll have to do some investigating...if not I'll have BMW take initiative and solve it. That's why I got a warranty |
11-08-2013, 01:24 PM | #20 | |
European Editor
10594
Rep 22,992
The only way to keep the peformance your friend had before is with BMW's PPK2 sw tune or with an aftermarket tune. Sorry to be the bearer of bad news.
11-19-2013, 09:17 PM | #21 |
58
Rep 200
Because im not a 'spirited' driver all the time, I dont really notice a difference in performance. I'm much happier having predictable acceleration from a stop as well as no stalling while in traffic now. To me, it was a safety issue for the street. If I were tracking my car, I'd be real upset.
I would really like to see a dyno run between the 2 SW versions to know how much power was lost. No turning back but I'm happier now anyway so it doesnt matter to me.
2011 AW 135i
11-19-2013, 09:26 PM | #22 | |
58
Rep 200
2011 AW 135i
