ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      10-03-2013, 12:33 AM   #1
i2ichal2dZ4M
63
Drives: 2007 BSM Z4MC
Let talk Wiper Blades!
I'm pretty much driving with no blades since the rubber piece tore off the other day. What does everybody recommend? I am open to trying aftermarket, and also okay with OEM.
Are replacement insert still available?
Thanks! luckily it doesnt rain in Socal until later in the year!
2007 BSM Z4M Coupe - 18" VOLK TE37 - 18" Apex ARC-8 - GC Track/Street
      10-03-2013, 01:27 AM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
For dealing with Seattle weather I've had the best luck with the OEM inserts. I had a pair of Bosch Icons turn into a noisy streaky mess after 2 months and the OEM ones I have now just might be almost a year old.
Too bad the inserts aren't available anymore.
Straightaways are for fast cars, Corners are for fast drivers.
      10-03-2013, 04:12 AM   #3
cossied
Drives: 2008 z4 3.0si
I changed the OEMs for Bosch aeros I found them much better.
      10-03-2013, 07:10 AM   #4
007MCoupe
007MCoupe's Avatar
94
Drives: '18 Sakhir M3 ZCP
I got a pair of those Rain X blades and in Germany they're great. Rain/snow/mud/bugs, no streaks
      10-03-2013, 09:33 AM   #5
Gladius
Two Wheels or Four?
Gladius's Avatar
93
Drives: '18 Perf Edition m240i
The dealer just changed mine out (extended maintenance), so they must still have the inserts. The invoice doesn't show the full wiper head, just the blades.
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      10-03-2013, 09:47 AM   #6
jdoublehcubed
Mechanical Engineer
96
Drives: 2006 Z4MR, Imola Red
I find the rainX lattitudes to work the best, but I usually use Bosch icons because the look soooooooo much better. The rainX's are probably 15% better. if you live somewhere with a lot of rain (not seattle, i mean actual rain like upstate NY or Minnesota) you might want to go with the rainXs.
      10-03-2013, 01:50 PM   #7
Living Dead
Zed Head
Living Dead's Avatar
314
Drives: 2020 BMW Z4 M40i
I've been driving for 33 years now and have tried almost every blade out there. Some are slightly better than others but none really last more than 6 months before they start streaking or chattering. There is no real advantage to spending $20-30 per side for some brands. Some aftermarket blades don't conform to the bottom right corner (about a 3 inch triangle). My recomendation would be either get the refill from the dealer or buy a cheap aftermarked set like Anco every 6 months and use Rain-X liberally and fill your washers with Rain-X wiper fluid.
      10-03-2013, 04:28 PM   #8
unluky
unluky's Avatar
7528
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
This reminded me of a question I had....
My drivers side blade has a little "spoiler" on it (not sure what up call it) that add's extra downforce in the wind. The passenger side does not. My questions was - is this stock? If so, should I have 2?
Just curious........
Matt
      10-03-2013, 07:17 PM   #9
beta
80
Drives: 2006 M Roadster
Stick with OEM, $13 bucks using part number 61611470281, includes both sides. Takes five minutes and they work great.
There's just one, you're good.
      10-03-2013, 07:41 PM   #10
wonton180
wonton180's Avatar
Drives: 07 Z4MC
It's funny you guys mention OEM wiper inserts. I've been denied from my local BMW dealer (6 months ago) when I attempted to purchase wiper blade inserts. They claimed they're not stocking them anymore, and require purchasing the wiper blade holder as well. According to realoem, there's still a part number for the insert rubber.
I've been using PIAA silicone inserts in my other car. they seem to work well....available on Amazon in different sizes.
      10-04-2013, 12:07 AM   #11
i2ichal2dZ4M
63
Tischer has these for 13 bucks + 12 dollar shipping! anywhere cheaper?
      10-04-2013, 09:48 AM   #12
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
ECSTuning also has them for about $13. Their shipping was only $7.88 to me in NY.
      10-04-2013, 12:55 PM   #13
beta
80
More than likely it was the old part number which was discontinued. I had (kinda) the same problem, I used an old part number that was all over the forums and tischer just removed it from my order. For some reason the old part number didn't forward to the new one, leading people to think they were discontinued.
You should check your dealer as well. On small cheap items they are sometimes competitive in price.
      10-05-2013, 11:53 AM   #14
the dink
Drives: 2005 Z4
Use OEM blades and if you clean them on regular basis like when you gas up they last much longer. Wipe the rubber part of blade get the dirt and crud off they last longer.
      10-05-2013, 12:37 PM   #15
bdc
Drives: 2007 BMW Z4 3.0i
I also have a spoiler on one blade but not the other. I assumed it came that way.
      10-06-2013, 10:09 AM   #16
the dink
Drives: 2005 Z4
That should be good for about 5mph
      10-07-2013, 01:01 PM   #17
thelinux
14
Drives: 2008 Z4 3si
Anyone tried e89 wipers on e85? They are the same sizes so they might fit?
zpost
