09-26-2013, 09:25 AM | #1 |
11
Rep 319
What would you do in this situation? A Tale of Two VANOS solenoids...
So I get the dreaded Engine Malfunction when on 100% throttle for any length of time.
It really only manifests itself on the highway, as I'm rarely on 100% throttle during city driving. Cleaned out the VANOS solenoids a few weeks ago, and noticed a big improvement in overall performance. But would still get the Engine Malfunction warning. Being impatient, I ordered a pair of new VANOS solenoids from ECS Tuning, and now they're sitting on my desk looking at me. I also ordered the Bavarian Technic scan tool, but that won't be here until Monday. I also really need an oil change. The rational part of me wants to wait until the scan tool comes in, just in case only 1 of the solenoids is bad, which I suspect may be the case. The impatient part of me wants to leave work right now and swap the solenoids really quick and go for a test drive. ahhh... what to do, what to do. |
09-26-2013, 10:09 AM | #2 |
28
Rep 275
man-o-man same f**king problem on my 08 135i
got code 2a87 on the outlet/exhaust side. Changed oil Swapped both code is still on the exhaust side. going to remove them both and clean them with carb cleaner. I only have the engine malfunction light when WOT 1st 2nd and 3rd car drives great with everyday driving even pushing it up to 5500rpms. its just WOT. |
09-26-2013, 11:50 AM | #3 |
18
Rep 254
Same issue. Just replace both. It's not worth it to go through the effort of getting to them and cleaning them just to put the same old part back in. I replaced both about a month ago and car is running nice and strong now.
cdv delete | clutch stop | bmw performance ssk | meisterschaft gt | berk mids | dinan cai | helix fmic | m3 subframe bushings, swaybar, front and back suspension bits | dinan stage 1 suspension | dinan cf strut brace |gc camber plates | dinan oil cooler | apex ec-7s w/PSSs | cobb stage 1 + fmic
09-26-2013, 12:15 PM | #4 | |
11
Rep 319
But whenever I'm reminded, it is really really really annoying turning my car on/off to reset errors. This isn't my damn PC! |
09-26-2013, 12:16 PM | #5 | |
11
Rep 319
Ahhh. |
09-27-2013, 05:21 AM | #6 |
57
Rep 552
Scanning the car would be great for diagnosis - it'll alert you to what code it is and at least point you in the right direction. It may be your vanos solenoids, but then again it could be something completely different. Then again, I guess you've already bought the solenoids... but you could sell them on if the problem was something else
09-29-2013, 07:44 PM | #7 |
59
Rep 913
I had the exhaust code. Cleaned and swapped, still got exhaust code. Put new ones in, went and changed the oil right after. Have not had the code come back - and this is after about 10-12 dyno pulls.
To anyone with this issue, I'd suggest just replacing both and being done with it. |
09-29-2013, 07:46 PM | #8 | |
59
Rep 913
Cleaning didn't work for me. Since replacing them both though, no more error. |
09-30-2013, 07:53 PM | #10 |
59
Rep 913
^ I should have paid more attention to your original post. didn't clue in that you weren't actually reading codes at that point. The engine light can be any number of things. 30FF definitely is not a vanos code.
Oh well, vanos solenoids going are common enough that you may very well have had to replace them in the future anyway. Sounds like 30ff is caused by boost leak. |
09-30-2013, 11:19 PM | #11 | |
15
Rep 678
do you get the 30FF in prolonged pulls? this code can be a boost leak or boost control issue. Like Boost solenoids, vacuum lines, vacuum tanks etc. if you've installed any performance part along the intake such as a CP or IC, I would look at those connections first. |
10-01-2013, 04:07 PM | #12 | ||
11
Rep 319
I did gain a lot of power back (that I had no idea was missing) when I swapped both VANOS solenoids for new ones. I *suspect* my rattling ass wastegates + the 30FF are inter-related. Only mod is JB3, but it's on Map 0 and has been for the past year or so. The Engine Malfunction light occurs within 10 seconds of going WOT in 6th gear, never (or so rare that I've forgotten) in gears 1-5. |
10-01-2013, 05:03 PM | #14 |
15
Rep 678
10-01-2013, 06:00 PM | #15 | |
11
Rep 319
Is it safe to close the door with something plugged into the OBD2 port? Looks like the door panel will hit the shit out of the connector |
10-01-2013, 06:26 PM | #16 | |
15
Rep 678
Yes the BT tool can log. not the friendliest for logging but it does the job. |
10-01-2013, 06:27 PM | #17 | |
11
Rep 319
Then... off to log some data! This gives me an excuse to go acquire dinner. Better make sure the laptop is charged up. |
10-01-2013, 06:29 PM | #18 | |
15
Rep 678
There is a looong list of variables, you don;t want to go through it more than once. Believe me lol |
10-01-2013, 11:21 PM | #20 | |
15
Rep 678
I kept throwing money when I had the E90 335i, and changed everything and I kept getting the dreaded 30FF. It turned out to be the boost solenoids in the end. |
