      09-24-2013, 11:18 PM   #1
Smiley1175
Smiley1175's Avatar
Australia
283
Drives: M2
Pads ... Not the libra kind
Hi all,
Anyone know where I can get a set of track pads for the 1M (M3 shape, size) before the weekend?
I'm looking for the Ferodo DS1.11 but open to other comparable options (endless ME20, etc).
Don't want street/track pads, looking for something I swap out for track days only.
Cheers
Ian
      09-24-2013, 11:33 PM   #2
skidz
16
Drives: 1mers nuts :D
southerm BM ??
      09-24-2013, 11:50 PM   #3
Smiley1175
Smiley1175's Avatar
Australia
283
Drives: M2
Originally Posted by skidz
southerm BM ??
Thanks mate.
Called them up. Nothing in stock.
      09-24-2013, 11:56 PM   #4
skidz
16
stu??
      09-25-2013, 12:01 AM   #5
Wizzzz
Wizzzz's Avatar
Australia
11
Drives: X3 M40i
Jin or Steven @ ActiveMotorwerke?
Evans @ Tyrepower North Melbourne?
      09-25-2013, 12:28 AM   #6
RadiuM
RadiuM's Avatar
Australia
38
Drives: 135i, 97 GTR VSpec
I get my ferodo's for the 135i from vsport.com.au
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec
      09-25-2013, 12:39 AM   #7
Giveway74
Giveway74's Avatar
Australia
13
Drives: 130i and MK7 Golf GTI PP
try vsport.com.au
2006 E87 130i
M3 front and rear arms, M3 Front and rear ARB , Quaife LSD, BMW performance wheel (non electronic), 135i Brakes, DS2500 pads, Apex wheel studs, Adjustable Bilsteins, API Half cage, Hankook Z221's (track) and Bridgestone RE002's (street) 225's all around
      09-25-2013, 02:10 AM   #8
timbo_3101
Australia
18
Drives: Slow
Originally Posted by Ian///M View Post
Keep in mind that the front are the same as M3, but not the rears
How did you come across this, Ian? Sounds interesting ...
I have five sets of pads, and they are generally purchased as E92M3 equipment (equivalent to 1M), although one set was handed down from an E90M3 racer.
      09-25-2013, 03:20 AM   #9
timbo_3101
Australia
18
Drives: Slow
Okay, thanks Ian (Syd). I think our brake issues are behind us, through trial and error (avoid OEM if at all possible).
Ian (Melb), I hope you find prompt resolution because there is one particular 1M hunter who will show our brothers no mercy on circuit.
      09-25-2013, 04:23 AM   #10
Smiley1175
Smiley1175's Avatar
Australia
283
Drives: M2
Thanks for all the replies.
So far no luck getting a set of DS1.11, 3 weeks away apparently.
I'm away next week so I think I've just left it all too late. Might have to do Phillip Island with oem setup.
      09-25-2013, 05:43 AM   #11
flinchy
126
Drives: E82 135i
1M & M3 part numbers from BMW are different for OE rear pads. They are slightly different in shape. I was advised by dealer that pad compound also different.
I used E9x M3 rears for DS2500 pads, but no way the sensor would fit, where it does on an M3. The shape is marginally different too.
Something about the brake bias being more neutral-rear in the m3
For the track, http://www.1addicts.com/forums/showthread.php?t=559124
People seem to haven't had an issue just putting on m3 pads front and rear, given calipers, rotors.. Entire rear axle.. are identical, they'll fit.
What's with the sensor not fitting though?
Via ecstuning, realoem and bmminiparts, ALL e9x and e8x share the same wear sensors.. Sounds like an issue with those pads, rather than being m3 or 1m pads
      09-25-2013, 09:04 PM   #12
oystero
Australia
17
Drives: AW 1M, E90 320d
Sorry to hear that Ian
Your other option is to use the pagid yellow for this round ?
Oem setup on PI should be fine if you only push it hard for 2 laps max per session.
In our last piarc run I brake earlier like how I would drive on the street and it went thru all 5 laps per session ok. 3rd hot lap i started to feel the slight spongy feeling
1addicts
