09-16-2013, 07:53 PM | #1 |
29
Rep 313
z4 stock antenna length and diameter of bolt?
Hi... my previous Z4 had pretty good reception...the stubby was worse...but the stock antenna was good. My BRZ now has terrible reception for HD... it goes in and out...I know a longer antenna is better. I gave my stock antenna away when I traded it in.. kinda upset about that...
Can someone help and tell me how long the stock Z4 antenna length is...not the stubby one...the whip antenna and if you know how long the diameter of the bolt of the whip fuba antenna? Appreciate if someone can help. Thanks |
09-16-2013, 11:37 PM | #2 |
My other car is on Mars
636
Rep 3,124
The first part of your question is easy, sort of.
It's 17.25" from the car body to the tip, but that only tells part of the story. It's a wire antenna helically wound around a center support, so it'll act as though it's longer than it really is. If you want to match its performance, you'll want one of similar design, or a straight antenna that's about 50% longer. I have no idea on the bolt.
Warning: May contain traces of nuts.
09-17-2013, 01:13 AM | #3 | |
29
Rep 313
I just hate getting rid of something then only realize I need it. So FYI, they make them in 7, 9, 11, 16, and 18" lengths... I'm going to try 11 and 16" then the bolt size I don't know about because I don't know if different manufacturers use a standard antenna bolt size. Thank you again for letting me know. |
