08-29-2013, 10:42 AM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Which Fuses are Part of Security System?
I'm having the same exact issue described here:
http://www.bimmerfest.com/forums/sho...d.php?t=616547 I've replaced the ignition switch but still having the key chime issue so I think it may be one of the fuses. Does anyone know which fuses I should be looking for? |
08-29-2013, 10:48 AM | #2 |
2432
Rep 11,667
another name change?
...going to have to start adding -villa to it not sure about the fuse.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 08-29-2013 at 10:55 AM.. |
08-29-2013, 10:52 AM | #3 |
2286
Rep 12,565
new car in the works my friend! surely that's a justifiable reason for a name change...
08-29-2013, 10:56 AM | #4 |
2432
Rep 11,667
suspected as much
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
08-29-2013, 01:21 PM | #5 |
127
Rep 1,772
Drives: 2007 Z4M Coupe
What if you are Villa and punking us all along?
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust |
08-29-2013, 01:40 PM | #6 |
2432
Rep 11,667
there would be no disguising Villa post content.
....I think we're safe.
08-29-2013, 01:55 PM | #7 |
2286
Rep 12,565
So bout those fuses anyone? lol
08-29-2013, 11:09 PM | #9 |
My other car is on Mars
636
Rep 3,124
"EWS toroidal coil" is the widget you're looking to fix.
I just confirmed that simply holding the key next to the ignition switch starts the beeping. I suspected this when I couldn't find a "key is inserted but not turned" set of contacts on the ignition switch. I think it's the same thing that charges the key battery and interrogates the fob. It also seems to be able to tell the difference between a key and a screwdriver, so that rules out some rogue piece of metal setting it off, but just in case, you don't have a column mounted boost gauge or anything, right? Wish I would have found this sooner. I could have stopped you from buying a new switch. ews.pdf It looks like L1 is inside the trim around the lock. When you were in there replacing the switch, did you notice another connector to the trim around the lock (X1764)?
Warning: May contain traces of nuts.
08-30-2013, 02:16 AM | #10 | |
2286
Rep 12,565
08-30-2013, 10:59 AM | #11 |
636
Rep 3,124
Not entirely sure. It might be part of the lower trim panel, 32316758156.
Not entirely sure that it's the part that's broke, either. Just something associated with that circuit. Have you checked it with DIS to see if that module's reporting any failure? Update: I just looked at my car and I seriously doubt it's part of the lower trim panel. It sits over the end of the lock cylinder and doesn't even touch the trim. I can't find it on RealOEM.
