08-16-2013, 09:53 PM | #1 |
14
Rep 71
Question about upgrading angel eyes and headlight
Hi,
I'm curious to know what are the best led kit when it comes to upgrading the angel eyes and the headlight? I've looked around, some people say LUX, but expensive and flickers. Some say they use different brand and so on. I wanted to get some input on what I should watch out for when it comes to buying led kit for the angel eyes and the headlight. Also, I want to replace my headlight, although its xenon, it's still not bright enough for me. What are my other options without getting any error or causing condensation on the headlights? |
08-17-2013, 09:06 AM | #2 |
888
Rep 2,736
not really any input for the halo rings, I just bought some H8 blue colored bulbs and now they match the LED pipe in my headlight and are bright enough to be seen in daylight for DRL's for 15 dollars, they do look yellowish at night when they dim but don't care really, not spending 250 bucks on LED's till they get it right.
the HID's are not bright enough? its technically the brightest output of lighting technology available to you at the moment for the 1 series, unless you mod to an LED driving lamp not sure how you'd do that, though with LED you get a better spread and can get rid of the cutoff. but your not going to want to cut up your headlight to do so you'd need to engineer the headlight to work as an LED headlight and not sure that possible unless your a millionaire . but who knows I bet the Chinese are working on an LED headlamp conversion for HID cars as we speak..... the HID is much brighter than the brightest LED but all the stuff it goes through cuts down on its performance, LED not so much unless its a projector style LED witch hurts it some. here is the tech nerd jargon, •HID lamp: Source efficiency is typically 120 lumens/watt or higher. However, losses from trapped light, protective covers and lenses, inefficient ballasts and unfavorable operating temperature typically result in a measured system efficiency of 30 lumens/watt or less. •LEDs: Source efficiency can be 100 lumens/watt or higher, depending on the type and manufacturer of the LED used. There are no losses from trapped light due to the focused output of the LED, and secondary optics and protective covers generally reduce output by only 25% or less. LED power drivers are also more generally efficient than HID ballasts, and reduce system efficiency by 10-15%. However, even when efficiency reductions due to high operating temperatures are included, LED system efficiency often remains above 50 lumens/watt or higher. Last edited by -c-; 08-17-2013 at 09:17 AM.. |
08-17-2013, 09:42 AM | #3 | |
14
Rep 71
Really? Do you have pics of it on daytime and on night time? I'm just tired of the halogen angel eyes I have lol. I just want white led like the new 3 series. Anyway, where'd you get it? Could you send link? I guess coming from a honda civic with hid headlights, I got used to it, but I really like the headlights. |
08-18-2013, 11:25 PM | #4 | |
11572
Rep 11,136
08-19-2013, 01:10 AM | #5 | |
888
Rep 2,736
^^^^^what he said! the optics are different between the LED DRL of the new BMW's and our halogen design, so it will never function the same, short of you pulling the headlight apart and installing parts from the new headlights and making a big mess, but anything is possible with lots of money, the LED's will give you that pure white you wish but at the cost of DRL functionality as they are hard to see in the bright light of day. but at night they will be white, but not noticeable like the newer design. its a lot of money for color and loss of function. you will find the GP thunder and other blue 7500K and other lights are a very cheap and good option for making the halos appear more white and still function as DRL's. you will also not notice the blue as its hidden the lights just appear more white, now the drawback is at night the halos appear a little more like stock as the lights are dimmed but not a big deal. your lights are HID so your no different than your Honda, and if the halos warm light bothers you, you can always turn it off. just do a search for cheap GP thunder and other lights and youll see the difference. or you can go full HID back their but its way two bright but that's just an opinion. |
08-19-2013, 05:26 AM | #6 | ||
14
Rep 71
08-19-2013, 08:28 AM | #7 | |
11572
Rep 11,136
08-19-2013, 07:36 PM | #9 |
888
Rep 2,736
Also it seems that the color temp is not the same across the board when it comes to manufacturers, the 7500k halogens I bought look white where at 7500 k they should be blue at 8500 k It darn be near purple.
But as said earlier 5000 k. Is a very clean white light once you start going to 6000k Your turning more blue. The best part of just sticking with the halogens is the halos are designed for a bulb style light and its the cheapest rout with best performance. (DRL function) some who do the HID say its way to overpowering. You can go LED or HID but you have a hell of a time trying to package the ballast and all that jazz or just go with a good halogen save 100's and get 75 to 80% of what your looking for. |
08-24-2013, 10:19 AM | #10 |
200
Rep 2,799
BavarianX/OSS design and call it a day, they open up your lights and install bright led angel eyes over the top of the old ones, and you can choose to have your headlight housing blacked out and also have your amber vinyled over from the inside. It will give you a great aggressive look compared to those new 3 series lights.
thanks to MGallop |
08-27-2013, 01:34 PM | #11 | |
Rep 89
Drives: 2013 135is LBM 6MT
/// BMW 135is Coupe #51/586 | Le Mans Blue | MT | BB Leather w/ Blue Stitching | Glacier Aluminum | Premium Package | Heated Seats | HK
08-27-2013, 11:32 PM | #12 | ||
888
Rep 2,736
The halogens are a good cheap alternative till they get the blinking issues fixed. But I've heard of new tech coming for the halo lights for our cars but in the meantime just sticking with the halogens. |
08-28-2013, 07:42 AM | #13 |
Rep 89
Philips it is! Thanks!
08-28-2013, 12:47 PM | #14 |
11572
Rep 11,136
There are zero codes thrown on the PIAA bulbs in my X5. Halogen should never throw codes. I love my PIAAs but will but the Philips bulbs for my wife's 135i. They are around $100 and are made for the Asian market, not sold in Europe or North America. So yes, ebay would be our best bet.
08-28-2013, 09:53 PM | #15 |
88
Rep 524
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
09-01-2013, 12:52 AM | #16 | |
888
Rep 2,736
