08-15-2013, 02:04 PM | #1 |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
I test drove the 14 Competition Package today as well as a regular 14 LCI without CP. On the whole I was disappointed and couldn't sense much benefit beyond the cosmetic. Some quick notes relating to CP:
Positives of CP: 1) Ride height looks great. I saw the CP parked next to the non-CP 14 model and the non CP car has too much gap on the front wheel arch. I think they both looked fine on the rear wheel arch. 2) The steering ratio is better but progressively better. This means that off the center you can't tell the difference between a CP car and a normal 14, however when doing a sharp corner you turn the wheel less. I did like this, but at the same time I was disappointed because I expected the steering to feel more responsive when doing lane changes and it does not. BTW this ratio improvement is something I did not notice at first when driving the CP car - I only discovered it because I measured how much I turned the wheel going round a corner, and then did the same when doing the same corner in the non-CP LCI car. So the difference is there, but it isn't appreciable while driving. Negatives of CP: 1) Suspension may be a little too firm for our roads. I can't see myself using sport plus ever. Prefer the range on the normal model. On highway ramp, the CP package is too firm and loses traction because the car jumps a little over an expansion joint. You have to run it in comfort with CP on our roads. 2) Epsilon steering improvement over standard 14. In normal driving you can't tell. When taking tight corners on a city street is when you get the ratio benefit. 3) Differential tuning is not noticeable at all 4) Exhaust sounds the same as stock and pathetic compared with my Eisenmann Sport. Basically if you buy a CP, expect to also buy a separate exhaust. 5) Probably not a negative since you don't have to get them, but I don't like the 601M wheels. I do like the black accents. What I don't like is that they are too 2-dimensional. While they are concave, they are linearly concave. The 343M wheels seem more sculpted and aggressive when you look at off axis. 601M wheels look best straight on. Things not covered 1) I couldn't test the 15hp at the high end of the RPM range because I didn't want to exceed 4k rpm with an unbroken in engine. Up to 4k rpm the powertrain feels identical to the standard M5. Opinion on other 14 updates: 1) I LOVE the LED lights 2) I actually found the touch iDrive to be very good and quick. It's faster and safer than the wheel IMO. As a former palm user it's quite intuitive to me. 3) Armrest compartment is same as before 4) iDrive display is same as before 5) New grille is awesome and well suited to LI placement. 6) B&O lighting brightness issue persists. 7) Other updates are trivial. Conclusion: 1) skip the CP and if you just have more performance get the CCB instead. 2) get the LED lights 3) all LCI steering including base model have better feel however it's not enough to warrant early upgrade IMO. In fact a less sensitive driver like my girl wouldn't notice. 4) not much reason to buy an LCI IMO. In fact if you can get a much better deal on a 13 then you should do it. BTW I ordered my 14 (only because I always change my car every year, not because LCI is a big improvement). Waiting on ED date confirmation.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray Last edited by stealth.pilot; 08-15-2013 at 03:48 PM.. |
08-15-2013, 02:10 PM | #2 |
19365
Rep 10,166
Thats it LOL
Not even the steering or the stiffer suspension made you feel good? I need to drive this so called package now.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
08-15-2013, 02:17 PM | #3 | |
Knight Commander
559
Rep 5,948
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
08-15-2013, 02:30 PM | #4 |
4066
Rep 2,064
Thanks. What are your thoughts on positives/negatives compared to the 2013 (pre-LCI) M5?
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
08-15-2013, 02:36 PM | #5 | |
19365
Rep 10,166
Thanks, for a second I thought you were messing with us by only listing the "1)" and then listing "2)" but leaving it blank afterwards....
08-15-2013, 02:50 PM | #6 | |
Yankee Air Pirate
151
Rep 978
And Stealth, are you going to reveal for final color config or make us all wait to see what it is?
2020 ///M5 || 2019 540XI || 2014 ///M5 w/CP || My Epic ED trip report|| || 2009 BMW R1200RT
08-15-2013, 02:53 PM | #7 |
Savoir Faire
74
Rep 1,772
These are pretty much the sentiments of non ZCP M3 owners. Not a night and day difference between the two cars, but the differences are at least appreciable at the track or at higher speeds (neither of which you were able to be at). Thanks for the input
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel Sold:E46 323i |
08-15-2013, 03:01 PM | #8 | |
Knight Commander
559
Rep 5,948
Positives: 1) LED lights. These look cleaner, and they look fantastic when lit up at night or (as I saw it) in parking garage 2) Steering feel on center (although post March 2013s have this too). 3) Steering wheel design is more sporty 4) Grille looks much better (although same grille can be fitted to 2013 for $150) 5) iDrive touch (its cool, although you don't need it if you use the concierge) 6) Concierge service included in price 7) Adjustable bolsters if you are thin (I wear a size 44 jacket so not an issue for me) Negatives: 1) Price increase combined with lack of incentives which are available on 2013 2) LED halos look better on the pre-LCI car during the daytime. I find them to be bigger and more mean looking. Bottom line, I think LCI improvements are not that much, and the CP is weak sauce.
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray Last edited by stealth.pilot; 08-15-2013 at 03:21 PM.. |
08-15-2013, 03:09 PM | #9 |
4066
Rep 2,064
Thanks Stealth!
08-15-2013, 03:21 PM | #10 |
2873
Rep 7,885
Stealth thanks for the assessment and review. I will try to test one out this weekend myself.
It will be interesting to see the difference in steering, but like I have said before I have no problem with my 2013's steering feel or ability. I love the way it feels, so not a big deal to me. Right now the only reason why I would buy a 2014 is to change my color. I really wish sometimes I had Monte Carlo Blue. Just sometimes. Other times, I look at my Black Sapphire Metallic and it looks so badass. I have problems. Lol!
08-15-2013, 03:21 PM | #11 |
188
Rep 1,548
What is your 2014 M5 spec?
Same as your 2013 with lighting pkg?
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
08-15-2013, 03:23 PM | #12 | |
Knight Commander
559
Rep 5,948
08-15-2013, 03:40 PM | #13 |
188
Rep 1,548
Just out of curiosity. Why get a 2014 that is essentially the same car? Why not keep it another year? You are going to have to redo radar laser and exhaust...and tint and...
CURRENT:
08-15-2013, 03:41 PM | #14 |
27
Rep 199
Awesome, thanks for the comparo, Stealth. I was curious what your opinion of the new grill would be as relates to LI placement; from the pictures I'd seen it didn't look like a good fit. However, now that I know otherwise, I'd consider getting the new grill for my 2013. From where did you get the $150 retrofit figure? Thanks!
08-15-2013, 03:43 PM | #15 |
Knight Commander
559
Rep 5,948
I pay ED invoice and no sales tax. For me TCO is lowest at 12 months. I've done this before.
08-15-2013, 03:46 PM | #16 |
Driver
94
Rep 636
Very helpful and insightful writeup stealth, thanks very much man. You actually covered some of the 'inside' questions that many of us had that car review magazines wouldn't have covered. Again thanks and I'll reread it again
08-15-2013, 03:46 PM | #17 | |
Knight Commander
559
Rep 5,948
08-15-2013, 03:49 PM | #18 |
Knight Commander
559
Rep 5,948
Yes that's a far point, but I did do some fast cornering and take it as high as 80mph.
08-15-2013, 03:55 PM | #19 |
Driver
94
Rep 636
About aftermarket exhaust, I have 2 M5s, AW and MCB. First one has Eisenmann Sport-Race, while the sound is indeed more pleasant and flows more freely (you can't get the throttle release bang fart in a tunnel anymore) it's still not this car's strongest point. I love the sound of M5, but having raced a friend's CLS63 yesterday, I couldn't hear my own exhaust because of HIS exhaust when he was 1 car length behind. AMG's exhaust is louder and arguably better, its only downside I'd consider that it gets tiresome and very quickly. On an everyday basis M5's stock exhaust seems to be a good overall solution.
From this review I understand that CP's ///M Performance exhaust is something between stock and Eisenmann in sound quality and inevitably included in CP's cost. |
08-15-2013, 03:58 PM | #20 | |
Knight Commander
559
Rep 5,948
The CP exhaust was more like the stock exhaust, not in between the stock and Eisenmann. It sounded same as stock to me. I didn't exceed 4k rpm, but between 1k-4krpm and on startup they sound the same.
08-15-2013, 04:07 PM | #21 | |
43
Rep 428
"If your not careful the media will have you loving the people doing the oppressing, and hating the people being oppressed"
Malcolm X |
08-15-2013, 04:12 PM | #22 |
Driver
94
Rep 636
