M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      08-14-2013, 01:22 PM   #1
KKS53
Drives: '13 M3 Lime Rock '14 M5
F10 M5 Nominal Output
This is a question that has been bugging me so figured this forum is as good a place as any to get the answer:
Nominal output on BMW USA website for M5 is 552 hp.
All 3 variants of M6 are 560 hp.
The M5 output conflicts with everything I have seen and read out their that references both cars with identical engines with a stated max output of 560 hp between 6000-7000 rpm.
My confusion is compounded by the fact an ad (from BMW) that I saw at my dealer when I picked up my '14 M5 CP this past weekend states that the 15 hp increase takes the M5 output to 567 hp -- everything else out there references 575 hp for M5 and M6 with the CP.
      08-14-2013, 01:28 PM   #2
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
The way that it has been explained to me by a BMW Engineer, is that 560hp is the minimum horsepower this engine will ever produce, no matter if it 130F or -60F or you are at 15,000ft Density Altitude, 560 is the MINIMUM. At Sea Level in SoCal Dyno's have consistently shown no less than 600hp to the crank across many different M5's and M6's dyno'd. I'm guessing with the Comp Pack, you are looking at about 615hp-620hp at the crank on a day to day basis. Hope this helps clear the confusion.
      08-14-2013, 02:44 PM   #3
s62
Drives: Yellow
BMW NA lists the number in hp, whereas BMW AG lists it in PS (metric hp). To get from PS to hp you divide by 1.01387. So 560PS/1.01387=552.34hp.
Now the engine is claimed to make 418KW which is a universal unit. The thing is that
1KW = 1.35962152 PS = 1.34102186 hp
hence the confusion.
      08-14-2013, 03:50 PM   #4
KKS53
Thx for the explanation- I had a feeling there was a metric / non-metric element but BMW USA needs to fix their site as they are showing 552 for the M5 and 560 for M6 which is what was throwing me off. They should stick to the same unit.
      08-15-2013, 09:17 AM   #5
AlphaAlpineM6
AlphaAlpineM6's Avatar
37
Drives: 2014 BMW M6 & 2012 AMG CLS63
What he told you is accurate.
2008 M3 Sedan + catless + Tune
2012 CLS63 AMG
2014 M6 Coupe + catless + KW V3
2015 Porsche GT3
, 2015 M3, all stock, 1/1 Space Grey
m5post
