07-21-2013, 08:03 PM | #1 |
23
Rep 325
RPI exhaust - one side black?
See pic attached. Why is only one of the two exhaust pipes black? If exhaust is exiting both pipes (on each side of the car; 4 pipes total...only two of which are black), why would only one turn black?
07-21-2013, 08:06 PM | #2 |
#dubspec
6336
Rep 5,201
One has more flow. The other exits off the main. Just clean ur tips regularly. I have never seen tips that dirty lol
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
07-21-2013, 09:21 PM | #3 |
Rep 165
Very little exhaust travels into the smaller diameter pipe, even though there is a side port with a screen. I removed the screen and nothing really changed in terms of of the amount of exhaust soot/carbon buildup. Just keep it clean with soapy water.
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
07-21-2013, 10:05 PM | #4 |
23
Rep 325
Thanks guys. I really should keep them cleaner. The rest of the car is immaculate, but after a while I started thinking the black exhaust looked a little bad *ss. ;-)
07-21-2013, 10:08 PM | #5 |
151
Rep 1,134
Drives: '07 M Roadster
What they said, more flow out of one side. If you're DDing the car you'll see a lot more build up too. Try adding some of that Armor All Wheel Protectant Spray to them after cleaning them and it should reduce how much carbon builds up and should make the next cleanings easier too.
07-22-2013, 08:20 AM | #6 | |
23
Rep 325
07-23-2013, 06:20 AM | #7 |
tosser
31
Rep 988
lol wait, you've never seen tips that dirty?
my rpi's have only 3k miles on them and look much much much worse. my car sees the track at least 2 weekends a month, though. |
07-23-2013, 06:30 AM | #8 |
tosser
31
Rep 988
as much as I take pics of my car, it's funny I can't find one of the rear in my ipwn album! here's the closest I found...as you can see, even my outers have build up in them. The inners....eh lost cause lol.
