07-21-2013, 10:04 AM | #1 |
16
Rep 119
oil cooler problem?
hello everyone.
sometimes i can join track day, i find oil temperature so high。and my friend use ER oil cooler。 but still high about 130 degree!and who can give some good idea? august i join race。 thank you |
07-21-2013, 10:18 AM | #2 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
Are you on a stock tune?
Oil temps will be higher when pushing the car hard for an extended time in high ambient temps. 130 C is not too hot for the synthetic oil in our cars. |
07-21-2013, 11:18 AM | #4 |
4207
Rep 5,729
Drives: 2019 M2 Competition
Get an ER oil cooler and BMS thermostat bypass and you should be good
07-21-2013, 12:15 PM | #5 |
2619
Rep 2,819
In the 1M Supplemental Owners Manual, page 17 (this is the US spec english version) it states that at normal operating temperature the engine oil will be between 100 C and 150 C.
In normal driving, mine usually stays right near 100-110C, but definitely goes up when driving the car hard. The highest I have seen was about 125 C, but I have not been to the track yet. |
07-21-2013, 04:25 PM | #6 |
116
Rep 3,070
Also, what is the oil you use? I found that 0W-40 oil (among the factory suggested grades) runs cooler than 5W-30 which most if not all 1Ms left the factory with. The 0W-40 grade oil also warms up to normal operating temperature a bit faster so overall I find it better suiting the 1M or any turbo car with high performance.
Of course, you better find a fully synthetic and BMW approved oil (LL1-LL4), like the Mobil 1 0W-40 or its Castrol equivalent etc. to have a peace of mind on your choice of oil. I don't track (yet) but like previous poster CarJunkie max I got the oil temps of my car after extended aggressive, high speed (200 to 270 km/h top speeds) high rpm and frequent on/off throttle driving on roads, was around 125-130 C. At that type of slightly irrational driving I was feeling the brakes are getting boiled up first but not the oil/engine. Normally 110 C is the max I get in law-friendly driving. You also didn't make clear if your car has a engine tune or not. You would better have an additional oil cooler in that case.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
07-21-2013, 07:59 PM | #7 |
11
Rep 161
According to Castrol no problem with their synthetic engine oil if below 140 degrees (C).
I had a chat with Castrol a while ago. Reaching 130 degrees when racing on local tracks. Tuned car. An oil change per season. Listening to both BMW (CarJunkie above) and Castrol I don't see the need for another or different oil cooler.
09-05-2013, 01:40 AM | #10 | |
Supreme Allied Commander
3883
Rep 54,457
Drives: F80 M3
We have tracked and raced a 335i with a custom radiator and a stock oil cooler without any oil temp issues. At the same events, ER and Berk Technology were running their 135i's with large oil cooler and still run into temperature issues. Our data showed that the custom radiator is excellent at keeping the water temperature just a few degrees cooler, enough to keep the DME from going into water temp related limp mode. The big surprise is how fast the cooling system's temperature recovers to normal when the vehicle is not under full throttle. We only made a few of these radiators and one of them is still on a BMWCCA Club Racing 135i, which does both sprint and endurance races without it ever overheat. To combat the overheating issue you can use more distilled water mix(we ran only 10% coolant) in your cooling system along with an additive from Motul or Redline. Use a high quality 0W30 or 40 motor oil. We used Total 0W30 back in the Time Attak days with oil analysis done after each event. Blackstone Labs continue to recommend drain intervals of 6000 miles, which is just amazing for a track/race car. |
09-05-2013, 08:45 AM | #11 | |
167
Rep 403
But in the meantime... any thoughts on the effectiveness of these alternatives: 1) The upgraded 42mm radiator from PWR: http://www.pwr.com.au/portfolio/bmw-car-radiators 2) Adding (just) the supplemental radiator & hardware from BMW's PPK2 kit Thanks. Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers Last edited by wjk_glynn; 09-05-2013 at 09:24 AM.. Reason: Added link to PWR radiator |
09-05-2013, 10:10 AM | #12 |
103
Rep 677
Stock, our oil coolers are run at a certain(higher) temperature point. The BMS thermostat mod allows the oil coolers to run 24/7 thus being proactive and not reactive to heating. I drive my car very hard, and for long sessions. I am FBO + Software. Adding a FMIC does help with the heat-soak but more so in recovery time, it does not eliminate it by any means!(I too was expecting some miracle temp drop just from a upgraded FMIC) I did not see a large decrease in temperature until I had the thermostat installed/ coupled with FMIC. My temps now NEVER go above 240*F at it's highest/ worst! Also, keep in mind it is 90-95* in FL right now. Stock after 1-2 hard pulls, the gauge would creep over 250*F, and that is while completely STOCK! The hottest my temps go now is 240*F and that's after as many pulls as you want! This picture was after a 20 mile highway run w/ two bikes @ < 110MPH-155MPH.
I am convinced at this point, unless you simply can not drive/ operate the mechanics properly, my car will not overheat. I used to hate the N54 due to it's guaranteed heat soak, but once you solve that problem. You will never be happier in another car, especially on these little, and oh-so precise chassis.
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
09-05-2013, 11:22 AM | #13 | |
3883
Rep 54,457
Drives: F80 M3
10-15-2013, 08:03 AM | #14 |
73
Rep 549
FBO St.2+ with ER oil cooler and BMW 5w40 oil - I had 125-130 oil temp during the track days. So usually it didn't reach the 130 level. And the oil cools much better with the ER oil cooler during the cooling lap.
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
10-16-2013, 11:01 AM | #16 | |
European Editor
10604
Rep 22,992
Why can't we get some cheap alu radiators made in Japan like you see for older BMW models !?
10-16-2013, 11:02 AM | #17 | |
4338
Rep 6,196
Just an FYI. There is a CRAP load of parts in the kit. Could not believe how much is in there. Includes all new wiring and large relay blocks for the upgraded rad fan as well. For the amount of parts in there, I am sure it is cheaper to just buy the complete PPK2 at one of the discount online places and maybe just install the parts. |
01-14-2014, 03:04 AM | #18 |
26
Rep 274
resurrecting a dead horse here...
daunting task but, has ANYONE (aside from Harold) even attempt the custom-cut-and-fit, upgraded 42mm PWR radiators? it would be interesting to find out really how much work would be needed for this.
01-25-2014, 12:08 PM | #19 | |
167
Rep 403
E.g. http://www.turnermotorsport.com/p-14...xi-manual.aspx Is there another model? Thanks. Karl.
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
08-14-2014, 05:50 PM | #21 |
91
Rep 1,168
There's finally a direct-fit aluminum radiator by Mishimoto available (for 6MT only)! It hasn't been out for more than a couple months, but has anyone tried it? From all the feedback on these forums, it appears improving water cooling is more effective than oil cooling for preventing limp mode on the track. I've been considering adding just the auxiliary radiator from the PPK2 but this could be the way to go. Or both!
http://www.e90post.com/forums/showthread.php?t=950469 http://www.e90post.com/forums/showthread.php?t=999461 |
08-14-2014, 05:59 PM | #22 |
European Editor
10604
Rep 22,992
@Bullitt
@schnite @wjk_glynn @hyphy1 @MightyMouseTech @jackkk I met a guy with a 1M, who installed this mini oil cooler in front of his radiator... He said it worked great. I've also heard that some guys have gotten the 335d radiator fan to fit on a N54 car. Its not easy but it will go in with some cutting mod-ing. Also... TuningWerk sells a thicker alu radiator... but its not cheap. Here is that slick mini oil cooler setup...
