07-19-2013, 02:33 PM | #1 |
Rep 82
Clutch Adjustable?? Stiff going into gear at a stop.
I have the JB clutch and lightweight flywheel and it has some miles on it. It isn't slipping but it is getting harder to put the car in gear at a dead stop. WHen I do get it into first or reverse, the car moves forward or backward a little.
I know these cars supposedly have automatically adjusting clutches, but don't know how that would work with an aftermarket clutch. Thanks! |
07-19-2013, 02:42 PM | #2 |
2432
Rep 11,667
For what you describe the clutch face is not completely disengaging from the flywheel.
So, is definitely not friction material wear. Have you noticed the pedal height any different? Does the engagement point change at all? Has the clutch line been bled? If you have a clutch stop, take it off and see if the additional travel makes a difference.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 07-19-2013 at 02:52 PM.. |
07-19-2013, 03:19 PM | #3 | |
Dog Listener
703
Rep 7,850
07-19-2013, 09:57 PM | #5 |
My other car is on Mars
636
Rep 3,124
On my Toyota, the dingus that connects to the pedal had lots of threads and a lock nut, so you could adjust the length.
Not this one. If bleeding doesn't help, you may have a bad cylinder. Luckily they're not that expensive. Not sure what kind of PITA they'll be to replace. |
