M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      07-17-2013, 04:16 PM   #1
M5LA
Drives: 13 F10 M5 Alpine White - sold
How to change the interior lights?
Has anyone changed the interior yellowish lights to LED ones?
      07-17-2013, 04:17 PM   #2
stealth.pilot
Knight Commander
stealth.pilot's Avatar
559
Drives: 2014 911 Turbo S
It's been done by others. I bought the kit from EAS but haven't installed it. Too lazy to do it myself and don't want a stranger working on the interior!
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray
      07-17-2013, 04:38 PM   #3
DietCokeOfEvil
DietCokeOfEvil's Avatar
11
Drives: F10 M5
I have done it. It's trivial. Trickiest part is getting the center overhead light off. But there's a guide somewhere on the internet for taking apart the F10 for lights.
      07-17-2013, 06:29 PM   #4
M5LA
Do I need any special tool? Or just a screwdriver and a lot of care?
      07-21-2013, 02:19 PM   #5
vaibhav11
vaibhav11's Avatar
Drives: 2016 F10 M5 PMS Limited Editio
It's quiet easy... do a search on LED interior lights in this forum and look at my post, as well as some others. I bought the EAS F10 kit, as well as a trimming kit from EAS.
* 2021 BMW X7 M50i
* 2016 BMW F10 M5 Pure Metal Silver Limited Edition
* 2008 Lexus GX470
* 2000 Acura NSX-T
      07-22-2013, 01:11 AM   #6
M5LA
I did a search and could not find the post you mentioned. Can you attach the link? Thanks in advance.
      07-22-2013, 10:28 AM   #7
DietCokeOfEvil
11
Drives: F10 M5
http://www.bimmian.com/elements/page...ht/IXB/IXB.gif
      07-22-2013, 10:33 AM   #8
DietCokeOfEvil
11
Drives: F10 M5
Picture guide:
http://f10.5post.com/forums/showthread.php?t=468845
      07-22-2013, 10:55 AM   #9
jmh
Internet Crash Test Dummy
jmh's Avatar
331
Drives: F97 X3MC / F80 M3 / F90 M5
The BMW info on how to remove the dome light is attached.
Simply remove the plastic trim (outer ring) and use a small screw driver to
pop off the entire assembly.
All other bulbs can be easily replaced by just using a small screw driver and
pop out the lights.
If you had the doors open for a while the bulbs will be HOT , so be careful when
touching them
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      07-22-2013, 11:56 AM   #10
dasrast
Drives: e30 s38, e30 3.5T, e30 2.5T
Ok nice
      07-23-2013, 01:09 AM   #11
M5LA
Thanks
      07-30-2013, 12:02 PM   #12
vaibhav11
vaibhav11's Avatar
Here you go:
http://f10.m5post.com/forums/showthread.php?t=779077
I've been very pleased with the ECS Tuning LED light kit.
* 2021 BMW X7 M50i
* 2008 Lexus GX470
* 2000 Acura NSX-T
      08-07-2013, 05:52 AM   #13
Charlie Brown
Charlie Brown's Avatar
53
Drives: F10 M5 Azurite Black
I swapped to LEDs. It really updates the look of the interior. IMHO the car should have come from the factory this way. It's an easy DIY. As others have posted, use the info provided on the forum.
      08-07-2013, 12:10 PM   #14
kylek13
13
Drives: 2013 BMW M5 Frozen Grey
+1
      08-10-2013, 12:11 PM   #15
M5LA
I replaced every bulb except for the front doom. The instructions are for the 5 series but not M5. I just could not remove the clear plastic piece/lense. Are there any better tips how to remove that plastic piece?
      03-07-2014, 06:24 AM   #16
mrjoed2
210
Drives: '14 650 M Sport Edition
Hi Guys,
Just came across this old thread. I just took delivery of a '14 650 coupe and want to do the interior LED upgrade. Curious about one thing, the factory BMW 10 LED accessory has 2 different types of bulbs, 6 of the "wedge" and 4 of the "flat" type. Where are the flat type used? I know the doors/footwell/dome/glovebox are wedge. Don't see where the other type is used
Thanks
      03-07-2014, 09:15 AM   #17
v3n0m
57
Drives: 2013 MCB M5
There is a great guide with all the parts required here:
http://bd8ba3c866c8cbc330ab-7b26c6f3..._LED_Light.pdf
      03-07-2014, 10:41 AM   #18
mrjoed2
210
Thanks - my 6 series (F13) should be basically the same except for no rear dome and only 2 doors. Curious is there any difference between the 9 chip wedge used for the puddle and the 5 chip used for the footwell/dome? Connector is the same.
      06-09-2015, 11:57 PM   #19
aprasan
aprasan's Avatar
Drives: 2014 BMW M5, CP
Unhappy Beware!
So I got the EAS kit, and I got the trunk, and the door ones taken care of and then started the hardest part, which was the dome lights in the overhead console - Got the part out and all that, and even though the car was switched off, ended up shorting something while changing the bulbs leading to a 4 digit repair cost and a replacement head unit being shipped from Germany. Safe to say having learned the hard way, paid $300 including labor and got BMW to replace them all with the OEM LED kit. Now i'm stuck with an EAS kit that I need to get rid off! Keep in mind, i've changed LED interiors on BMWs and other cars successfully before, I just think the M5 is a little different. In hindsight, maybe disconnect the battery...
      06-15-2015, 09:26 AM   #20
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
812
Drives: 2013 BMW M5 | MSR Stage 3
Ouch - that really sucks... I recently changed out my lights to LED on my M5 and thought exactly about that. So glad that didnt happen.
m5post
