07-15-2013, 05:24 PM | #1 |
61
Rep 722
Driver side Angel Eye not responding
So my passenger side angel eye burnt out and I ordered a pair of LEDs and when I replaced the passenger side everything worked fine and then when I replaced the drivers side it would not turn back on when testing it. I made sure the connections were all tight and after doing so plugged the halogen bulb back in and nothing..
Anybody else ever have this happen? Did I blow a fuse somewhere? Any ideas welcome
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-15-2013, 06:35 PM | #2 |
43
Rep 272
Drives: 2008 128i
It sounds like you may have blown a fuse. I'd check them first
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
07-16-2013, 12:52 PM | #4 |
61
Rep 722
Thanks i found out the reason why it happens is because when the car senses an error electronically it cuts power to that device apparently if you put the oem bulb back in for a period of time it will reset going to try both to get them working because the one side looks great with the led
07-16-2013, 03:21 PM | #5 | |
Rep 61
07-16-2013, 04:32 PM | #6 |
61
Rep 722
Cycled both bulbs with battery and nothing then I looked at the wires and the driver side has little to no rubber covering left on it so it must of dry rotted I checked the code and it was consistent with the driver side bulb not sure how I'm going to approach this I think the dealer will try and charge me for a new headlight or something ridiculous. Anybody ever have to recoat the copper wires? Is it easy?
07-16-2013, 07:44 PM | #7 |
61
Rep 722
divided the wires and cover them with electrical tape and still nothing... completely out of ideas besides visiting dealer which i really rather not do..
