ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      07-12-2013, 12:45 AM   #1
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
VF570 Supercharger Dyno
Just a quick pull vid for those that are fans of the SuperSprint exhaust sound
Output is pretty low though....
My highest yields have only been 390rwhp and 300rwtq
Here is the most recent dyno sheet:
      07-12-2013, 02:13 AM   #2
beta
80
Drives: 2006 M Roadster
The sound is 10x louder and deeper than the video implies with huge pops. Definitely the best sounding exhaust out there.
Too bad that the power still isn't there for your VF570 kit after going to LA to get it fixed. I'm sure you'll sort it out
      07-12-2013, 04:00 AM   #3
mfanatic325
///M-fanatic
Taiwan
193
haha thanks V. You posting your vid up soon?
      07-12-2013, 06:21 AM   #4
BMW Maniac
22
Drives: Former Z4M coupe owner
Yeah, you are around 100rwhp less? Does the car feel like it is pulling timing, misfiring, or knocking? Any codes?
      07-12-2013, 11:04 AM   #5
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Very interested to hear what issues you find, that's a pretty big drop in power relative to what it should be. GL
      07-12-2013, 03:00 PM   #6
mfanatic325
///M-fanatic
Taiwan
193
What's odd is that there have been absolutely no codes, and the car has driven perfectly fine. I drive it daily and am very sensitive to any and all changes.
I miss how the car drove so smoothly when I had just bolt-ons and the Active Autowerk tune.
With VF's 570 kit, I'm running 550cc injectors, and it's just not perfectly smooth driveability-wise. I was told it has to do with the way our injectors run, but I recently test-drove an E92 M3 with a VF625 kit and it was smooth as a baby's bottom
As of right now, the power is consistent amongst three different types of dynos that I've strapped the car to. I guess I can't complain about the consistency, but I'm definitely disappointed that the power is so low compared to where it should be.
      07-12-2013, 03:12 PM   #7
BMW Maniac
22
So my next question is what does VF say? Are you making the amount of boost you should be? Sounds like there might be an issue with the blower....it is the main component to you making boost, so if you're not making the boost you should, it has to be the blower
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet
      07-12-2013, 03:35 PM   #8
marinb
marinb's Avatar
19
Drives: 2017 911 GTS
Dietsch Werks uses a SuperFlow dyno and those numbers could be way different than what you get on DynaPack or DynoJet. I remember Beta feeling like he pulled low numbers on that dyno as well.
Did you happen to get a baseline from your old AA setup at Dietch Werks before doing this? I know most of your previous run have been on a DynaPack, so maybe you should try that again to see how it compares. Or if you want to compare to the rest of internet, Dynospot Racing has a DynoJet.
      07-12-2013, 04:35 PM   #9
beta
80
They actually got tired of it and have a correction factor for DynoJet-like numbers, and I'm pretty sure that's the chart Lon posted.
With the adjusted numbers my dyno showed a peak power of 295 wheel which is what I expected for euro headers + tune.
      07-12-2013, 04:57 PM   #10
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
In the summer heat, our cars lose a LOT of power. I'm not surprised. I'd take it to the quarter mile, and see what your trap speeds are. 420rwhp should net 120 to 122mph. I was only hitting 116mph on my VT2-500 kit in the summer
Might be more telling than a dyno..
      07-12-2013, 05:45 PM   #11
pokeybritches
pokeybritches's Avatar
479
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Sorry to see it's still low. Maybe a compression/leakdown is in order?
The summer temps make a difference, but they don't make THAT much of a difference. Mine put down 405 rwhp in the Orlando heat last week on 5.5-6 psi. I would think the numbers would be closer to 430-440 whp.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
      07-12-2013, 06:12 PM   #12
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
What maintenance have you done on the motor? It's unlikely the kit as mine is running great with ~7000 miles on it now. I DD in 100+ degree weather with no issues; and still have enough power to spin the 275s up through 2nd gear in the heat...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      07-12-2013, 06:18 PM   #13
qqragoon
Drives: Lucio-II
Recently, I had the VF570 installed on my Z4MC and will do a dyno in coming weeks. looking forward to see if I am getting different numbers.
      07-12-2013, 11:02 PM   #14
mfanatic325
///M-fanatic
Taiwan
193
VF doesn't know why my car is so weak
They asked me for my supercharger's serial number, but have not replied back yet.
Looking forward to your numbers
I did valve inspection a little over a year ago, but other than that, just oil & filter changes :/
Yes, I posted the dynojet-corrected numbers. Still very low. Additionally, these numbers are synonymous with VF's in-house Mustang dyno.
I don't really do drag, nor do I have access to one nearby, so I can't really use that as a reference point.
Also, the weather was quite nice on the day of the dyno. I'd say maybe 70 degrees dry heat at most. There were plenty of fans being used as well, so I am not blaming the heat whatsoever.
      07-13-2013, 01:57 AM   #15
johanness
56
Drives: 2008 Z4MC
Damn bro, I hope u get this sorted. Here's hoping they'll come back with some info re: the supercharger itself.
      07-13-2013, 02:04 AM   #16
mfanatic325
///M-fanatic
Taiwan
193
Yeah...at least the output is consistent right now. Better than random boost and/or power levels or somethin'
Oh btw, I forgot to answer the question above: yes, I am running full boost, up to 9PSI, so I don't think it has to do with the charger, but who knows
      07-13-2013, 01:30 PM   #17
ZStig
279
be careful how you're reading the boost gauge, I know on my setup, if you bounce off the rev limiter, the boost will spike 2psi, and make you think you're making more than you really are
      07-13-2013, 11:11 PM   #18
mfanatic325
///M-fanatic
Taiwan
193
Yikes...well, I've only seen slightly short of 9psi when redlining via my wideband AFR controller + P3C gauge when keeping my eye on the gauge "live". Hopefully no issues.
But then again, seeing as how my car's putting out such little power, I'm sure there'd be no damage even if boost did spike 2psi
      07-13-2013, 11:30 PM   #19
Finnegan
Dog Listener
Finnegan's Avatar
704
Drives: Z4M/. Z3M, E36/46 M3
Wasn't this kit on EAS car? I wonder if they were making expected power.
Disappointing that VF couldn't help. Did they do a smoke test to check for boost leaks?
      07-14-2013, 12:55 AM   #20
mfanatic325
///M-fanatic
Taiwan
193
Yeah, it was on one of EAS's employee's car prior to my purchasing it. Not sure what kinda power they were making.
No smoke test that I know of. Boost test showed up to 9psi which is okay.
      07-14-2013, 12:52 PM   #21
Finnegan
Dog Listener
Finnegan's Avatar
704
Sorry Lon, I have my fingers crossed you'll be making full power soon!
      07-14-2013, 02:46 PM   #22
Endless619
DHS
Endless619's Avatar
203
Drives: 2023 M4, 2020 Land Rover
Why so low with numbers? Very close to a stock E9X M3 numbers. It should be way over that.
But lets say a stock E86 M dynos at around 270 hp to the wheels. Slap on a 100 hp SC kit and he should be at 370 hp. I dont see whats wrong with that. Are some of you folks claiming the kits give an added 200-300 hp?
If my mind serves correctly the VF SC for the S2000 and the SC kits for the NSX only gave you about 80-100 extra hp with the bolt on kits, with tune.
2020 Land Rover Velar Autobiography
2023 BMW M4
2016 X3
zpost
