07-09-2013, 07:45 PM | #2 |
Rep 146
If its under warranty, the dealership will probably do it for you if you ask (they did for me). If not, there is a great diy on the site with how to do it with floss.
07-09-2013, 07:48 PM | #3 |
Rep 80
I looked in the diy section and couldn't find anything, I'll look again. I tried the floss method but coukdn't seem to get the floss between the adhesive and the trunk lid
07-09-2013, 09:12 PM | #5 |
Rep 135
Not sure what's covered in the DIY, but from what I've done on other cars, Goo-Gone and clay bar seems to help take the adhesive off. Also, a hair dryer is your friend
07-09-2013, 11:33 PM | #7 |
Rep 34
I was able to peel some of the pieces off by hand, then had to heat them slightly. If you get under the "tape" then the adhesive comes off pretty clean. Otherwise you can just rub it and it'll come right off.
07-10-2013, 05:07 AM | #8 |
138
Rep 353
yes heat gun works great as does goof off. Also to remove the adhesive, easiest way is to push it with the ball of your thumb. takes a while but enough pushing tends to bunch it up and it rolls right off. I removed mine after two years on the car and you can't tell it was ever there.
07-12-2013, 08:04 AM | #11 |
472
Rep 928
I'm having some trouble getting some of the residual adhesive off the trunk. Being the weather has hardened the adhesive a bit and is being very stubborn. Do I just need to sit there longer with a hair dryer on it? I've tried soaking it with goo-gone & simple green, but neither worked.
07-12-2013, 02:21 PM | #12 |
1Addict
3234
Rep 7,894
how much is on there? I'd say hit it with some compound. You may have cooked it with the hair dryer to be honest.
Debadging, all I ever do is either use floss or a thin plastic spatula to pop off the pieces, then goo-gone and a cloth to get the adhesive off. Then claybar, compound, polish and wax the area.
07-12-2013, 03:04 PM | #13 |
61
Rep 722
Fishing line + Goo Gone will do it
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-12-2013, 04:17 PM | #14 | |
472
Rep 928
07-14-2013, 01:23 AM | #15 |
Rep 64
I've debadged multiple cars. I just let the sun heat the emblems. Then I use dental floss (sometimes multiple strings at same time) and saw through the adhesive; start at top then start from bottom so the cut in the adhesive meets in the middle and can pull emblem straight off. Then a little rubbing alcohol and then rub the adhesive off with your fingers. Then wash the area and wax it and it should look like no emblems were ever there.
One warning every time I've done it I have gotten blisters on the tips of my fingers from rubbing the adhesive off but I figure my fingers heal paint doesn't. I wouldn't try to use anything but your fingers and some sort of anti-adhesive that is safe for paint. |
07-18-2013, 11:38 PM | #17 |
Rep 32
On my old A4 I used warm water from a hose to get the adhesive warm so it would pull a bit, then some goo gone and then floss. And at that point, those badges were on for like 10 years and it left zero residue/evidence they were ever on.
07-19-2013, 12:01 AM | #18 |
331
Rep 4,021
Drives: F32 Coupé
Blowtorch.
