07-05-2013, 09:16 AM | #1 |
28
Rep 113
Rear Suspension Clunking Fixed
My rear clunking issue has been solved on my 10/2012 build. Service Center ordered the parts from Germany which included new rear springs and mounts as well as new front dampers. We have a lot of uneven, bumpy asphalt roads in the northeast and I am very satisfied with the outcome---no more noise over speed bumps or bumpy roads. If anyone has questions as to the the service advisor, I can help you. Repair was done at BMW Port Chester Service Center. I asked if they were going to isse a recall and my SA guessed they wouldnt.
07-05-2013, 10:18 AM | #3 | |
77
Rep 1,341
Drives: 2013 M5 SSII
07-05-2013, 10:55 AM | #4 |
27
Rep 199
+1. If you don't mind sharing (as this will really assist many of us) please PM the details. Thanks and congrats on a successful resolution!
07-05-2013, 11:30 AM | #5 |
Internet Crash Test Dummy
332
Rep 1,055
Drives: F97 X3MC / F80 M3 / F90 M5
Yep the "fix" is only performed on a "per complaint" basis , no recall is being issued
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
07-05-2013, 12:55 PM | #6 |
Rep 15
Can you describe the 'clunking'? Although I've heard of this issue, my build is July 2012 and I've never experienced this for some reason. Is it pretty obvious when going over bumps at 30+ mph?
Thanks. |
07-05-2013, 04:28 PM | #7 |
11
Rep 94
I get this going over speed bumps and at other random bumps. I assume this is the clunk that is loud and you look back and think you might have hit something or lost a part . Would love to see what they did if you will share
07-05-2013, 10:04 PM | #8 |
73
Rep 254
I hear an annoying noise coming from rear left side (no clunking) but just on certain uneven road surfaces. I went to the dealer 3 times . They removed the rear deck lid and trunk from my car. They thought it's either the seat belt or something inside the panel but got no help. They also checked the clamps by the exhaust and the heat shield they were not loose. I'm thinking its most likely the rear suspension
07-05-2013, 10:41 PM | #9 |
37
Rep 380
Drives: 2014 BMW M6 & 2012 AMG CLS63
no clunking here.
-- 2014 F13 M6
2008 M3 Sedan + catless + Tune 2012 CLS63 AMG 2014 M6 Coupe + catless + KW V3 2015 Porsche GT3 , 2015 M3, all stock, 1/1 Space Grey |
07-08-2013, 07:32 AM | #10 |
28
Rep 113
re
07-08-2013, 07:36 AM | #11 | |
28
Rep 113
re
1)remove and replace rear springs 2) remove and replace rear spring mounts 3) remove and replace front dampers 4) i remember seeing also, "addtional shock" so to be clear, the rear springs and mounts on top are removed and replaced to where the springs now stay attached to the mount--previously, they didnt travel long enough and separated from the mount thus prodcuing the clunk. front dampers are replaced. Over bumps and uneven its like a different car--i find it now much firmer in rear end--car sounds and feels now like the e60 when the f10 in firm setting---i still think the front end setup is a little to soft but that has nothing to do with clunking |
07-08-2013, 07:38 AM | #12 |
28
Rep 113
re
service clunk is not normal.its done a on a per client and was told they likely wont recall it. there is a fix for it...tell your sa to put a call into germany--
07-08-2013, 08:09 AM | #13 |
Rep 47
Reported the case of rear noise to service center, they checked and decided to order those parts.
Have it replaced in 1 day and no more noise. i then asked them what abt. the front. they said they couldnt hear any noise (which is true) and they wont replace. So i guess i should wait until if noise appears at the front?
13 F10M5, LP570-4
12 Facelift C63 w PP, Gallardo Superleggera 10 997 GT3RS, C63 w PP |
07-08-2013, 10:13 AM | #14 |
28
Rep 113
re
There usually is no front noise. However, it seems there must be new specs on the front or proper dampers. all fixes to address rear clunking involve new front dampers.
07-08-2013, 01:12 PM | #15 |
11
Rep 94
Just to make sure I am hearing the same thing if I hit a doped bump or sometimes a pothole etc it almost sounds like something broke off the back end. It is very noticeable and freaks me out every time it happens. I would say it happens 3 or 4 times a month. Sound right?
07-08-2013, 01:48 PM | #16 |
187
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
I have a Feb build 2013, havent heard any clunking. Does that mean it was addressed during production? Do any people with later production dates have the clunk?
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
07-08-2013, 03:07 PM | #17 |
28
Rep 113
re
I had heard a while ago that the clunking was being addressed on or about DEC 2012 builds. Clunking is apparent when you are travelling at a crawl and go over a moderate size speed bump. You will hear a sound that appears to come from the rear deck lid or upper trunk. You may also hear it a slower speeds over very bumpy roads. the sound is the springs disconnecting from mount then reconnecting.
ornicar136.00 |
07-08-2013, 03:09 PM | #18 | |
187
Rep 2,245
07-08-2013, 06:03 PM | #19 | |
174
Rep 837
07-08-2013, 06:23 PM | #20 |
Rep 43
I fixed this issue 3 months back too. Its not a recall issue and if you complain hard enough, BMW will see to this problem. It's a day's job and its totally free.
07-22-2013, 11:00 AM | #21 |
332
Rep 1,055
Official SIB is forthcoming : SI B33 01 13
Cause : Rear coil springs rebound rate is too aggressive Solution : Replace the rear springs and the front and rear auxiliary springs (bump stops on struts)
ornicar136.00 |
07-22-2013, 11:19 AM | #22 |
1231
Rep 4,106
My car is 4/13 build and I dont have the rear clunk. Was anything changed for 2013 production?
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
