06-11-2013, 04:21 PM | #1 |
Perception is King
131
Rep 1,703
Removing top plenum cover
Hay guys how do you remove the Top Plenum cover, ive removed the two top nuts off the top but it doesnt seen like is even close to budging, Any help would be much appreciated.
Thanks
Perception and Reality are Two totally different Things.
06-11-2013, 04:28 PM | #2 |
BimmerPost Supporting Vendor
8256
Rep 18,845
Drives: BMW
Intake halves are bonded together, the rods serve as stabilizers at this point. The halves can't be separated without cutting.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-11-2013 at 04:59 PM.. |
06-11-2013, 06:50 PM | #4 |
158
Rep 637
Drives: Nissan GTR / F06 M6
There should be ring clamps on each of the throttle bodies that you have to loosen up. I believe they are 6mm nuts.
check this picture you can see the ring clamps around each throttle body. |
06-11-2013, 06:52 PM | #5 |
_______
169
Rep 1,088
Those two bolts on the top do nothing for the removal. As aznboi319 said above, loosen each of the throttle body clamps, then pull up. Disconnect your IAT sensor first.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
