BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
European Auto Source (EAS)
      09-21-2007, 04:09 AM   #1
southlight
Moderator / European Editor
southlight's Avatar
1540
Drives: X3M
M3 Aftersales Training Information
For you guys waiting for the US introduction. Here's the BMW M3 Complete Vehicle Guide as found on bimmerfest:
http://www.m3post.com/goodiesforyou/...nformation.pdf
Best regards, south
      09-21-2007, 08:20 AM   #2
rvacha
rvacha's Avatar
62
Drives: '08 E92 M3
2008 E92 M3  [0.00]
Thanks South! Some interesting tidbits in there:
1. Transmission oil is not considered "lifetime"
2. Clutch and dual mass flywheel must be replaced as a single unit
3. Verification that EDC is passive in sport mode
4. Unequal length half shafts (I'm surprised)
5. Knock ion detector failures can cause audio system problem (who would have thunk?)
6. Same transmission as used in 335i and US release E60 M6 (except cooler is added). Either the diff is really efficient or the S65B40 is underrated based on limited dyno charts available to date
7. Very little changes for the US release (seat cushions, fuel tank leakage diagnosis module) means no power derating or weight gains
8. Unusual firing order for a V8 engine
9. The DME is "only" rated for 9,000 RPM, so increasing rev limiter might be difficult if not impossible.
10. Excessive transmission oil temperature can invoke limp home mode
Can anybody point me to the equivalent E60 M5 PDF (that is not scanned)?
'16 F30 340i xDrive 6MT Melbourne/Black
'08 E92 M3 6MT Jerez/Speed Cloth
'18 F80 M3 6MT SO/CSAT
      09-21-2007, 08:54 AM   #3
Keto
Keto's Avatar
73
Drives: F80 M3
2015 BMW M3  [10.00]
Mmm, fun read.
      09-21-2007, 09:18 AM   #4
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Not surprised the 6MT is shared among other platforms... Actually kinda figured that.
Tranny fluid not considered lifetime is also not much of a surprise.
However, the other stuff is interesting...
Glad to hear we wont be getting strange seats or other weird configurations in the US...
Jason
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      09-21-2007, 09:46 AM   #5
mkoesel
Moderator
7515
Drives: No BMW for now
I was actually hoping the ratios on the tranny would be a little closer than on the 335i.
      09-21-2007, 09:59 AM   #6
the_stranger
the_stranger's Avatar
India
37
Drives: e92 M3 6MT
M-specific options:
• MDrive menu
• EDC-K
• 19" M3 rims, tyres
• Seat back width adjustment (passive)
• Enhanced leather interior
• High speed down-control option 7ME "M
Driver’s Package" (280 km/h).
Individualization options:
• BMW Individual High End audio system
• Individual highly-polished shadow line
• Individual interior trim
• Individual paint finishes.
Does this mean iDrive is standard???
2008 e92 M3 6MT AW/BLACK (SOLD)
2009 e92 M3 6MT AW/FR
      09-21-2007, 10:28 AM   #7
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
iDrive
No, it's just not an M-specific option.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      09-21-2007, 02:38 PM   #8
Stahlgrau
Drives: Backwards
Oh man, imagine this thing at, or near, 9000RPM's.
      09-21-2007, 03:06 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Gear ratios
Rear axle ratio is considerabley lower at 3.85 compared to 3.08 on the 335i. That's a 25% lower ratio (higher numerically), offset about 2% by the slightly larger rear tires.
      09-21-2007, 03:13 PM   #10
GregW / Oregon
Commander-In-Chief
2122
Tech info
Thanks--fascinating info. Just read that the low pressure VANOS saves about 18.5 lbs compared to the S85 system. Also, clutch and flywheel weigh 8.8 lbs less than the M5's.
      09-21-2007, 03:23 PM   #11
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Right. Good point.
      09-21-2007, 03:24 PM   #12
mkoesel
Moderator
7515
Absolutely. But that won't change the difference in gearing between the different gears, unfortunately. I was hoping to see the a better spacing between 1st and 2nd and 4th and 5th. I think we'll see ratios that are better matched to the S65 with the M-DCT box. Of course it will have 7 speeds too.
      09-21-2007, 04:53 PM   #13
swamp2
swamp2's Avatar
611
Drives: E92 M3
Very interesting - lots of detail
Nice document. Notice the production has been done predominantly with CAD. This means the pictures in the manual are the 3D digital engineering designs/"drawings" used by BMW adapted for this guide. Pretty cool and likely also a time/cost savings for BMW.
The things I found most interesting:
  • Differences to M5 engine include: oil system, VANOS (low pressure), weight savings, MSS60 engine control vs. MSS65, double roller cam chain vs. single (most of which we already knew)
  • Lightweight carpet
  • Key dependent M-drive settings (for "certain" settings) - cool!
  • Mirrors became larger to comply with future legislation
  • Seat shape and foam is different in EU compared to US
  • Pistons contain a "running in coating" containing tin and are identical to E60 M5 pistons
  • Low pressure VANOS saved 8.4 kg compared to M5 system
  • One piece radiator in the M3 compared to two piece in the M5
  • Document seems a bit contradictory about the transmission. In one place it says the transmission is based on the US 6MT in the M5 but when it lists part numbers is show it identical to the 335i. I think, as I predicted all along all three are almost identical with the M3 even sharing the 335i ratios.
  • 4kg reduced weight in the clutch compared to the M5
  • Driveshaft cv joints from M5 (nicely over-rated for the lower torque in the M3)
  • Completely different front end geometry compared to 335i
  • Interesting that they published the detail on EDC and the graphs of damping force vs. piston speed and the dynamic range of adjustment obtainable by EDC.
      09-21-2007, 05:07 PM   #14
The CSL
For the love of ///M3
The CSL's Avatar
19
Drives: Peugeot 306 XSI 16v
Nobody picked up on the fact you can have Individual paint in the US...
      09-21-2007, 05:10 PM   #15
lucid
lucid's Avatar
374
I saw that. Is that really the case, or are we missing something?
      09-21-2007, 05:28 PM   #16
GregW / Oregon
Commander-In-Chief
2122
Individual paint
This is a European publication. Where did you see this as US specific?
      09-21-2007, 06:23 PM   #17
swamp2
swamp2's Avatar
611
Drives: E92 M3
Confusion
I think I know why he/she thought this. I was confused by it initially as well. When south mentioned the US in his OP I think he just meant here is some information for us bored in the US. He did not mean that the document is specifically describing the US car.
      09-21-2007, 09:42 PM   #18
rvacha
rvacha's Avatar
62
Drives: '08 E92 M3
2008 E92 M3  [0.00]
True, but the document DOES specify some differences between US spec and non-US spec versions (implying it applies to the US as well), and it is a goal of BMW and many others to build "world cars" that don't need to be modified to sell in specific markets. The practice, for example, of selling ///M cars with different motors for the US market is long gone. The Europeans get smog performance above their requirements while we in the US get cars with pedestrian safety we don't even regulate. One car, all countries, that's the goal.
      09-21-2007, 10:24 PM   #19
mkoesel
Moderator
7515
That is exactly how I read it to.
True but when it comes to Individual paint, that is just an option. There are many, many options we do not get on US cars. Speaking generally throughout all BMW modes, I mean. Everything from different navigation and audio systems to wheels to trim packages to rear fogs to interior and exterior trim colors are more are left off of our option list. True, this applies less so to M cars, but I think we'll need something more substantial than this document to make conclusions about US spec cars.
      09-21-2007, 11:11 PM   #20
rvacha
rvacha's Avatar
62
Drives: '08 E92 M3
2008 E92 M3  [0.00]
I consider this stuff to be insignificant, but that's just me. When the E36 M3 hit the US shores it wasn't the options packages people complained about, it was the engine. When the E39 M5 hit our shores it was the lack of floating rotors. In terms of major mechanicals - the stuff that makes an ///M an ///M - what you see here is what we will get. Ours will not be unpowered, they won't weigh more, they won't be missing floating rotors. That's the stuff that matters, at least to me
      09-21-2007, 11:18 PM   #21
mkoesel
Moderator
7515
Gotcha. And I agree for the most part. I thought we were still speaking mostly about Individual paint as mentioned in the post by the CSL that spawned our replies.
      09-22-2007, 12:01 AM   #22
cncmastr
cncmastr's Avatar
1590
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
This is the best 112 pages I have read all week!
Tags
aftersales
m3post
