KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
06-02-2013, 11:52 AM | #1 |
21121
Rep 20,741
Drives: 2021 911 turbo
Picture wanted: PSS 265/35R19
I am at the point I need to replace the PSS on my car. I really like the PSS and want to stick with it. I am presently debating keeping my current size of 255/35R19 and 275/35R19 or going back to the OEM size.
I was pondering going back to the OEM size because of not much more thread width (+5mm at the rear) for significant extra weight (+2.9 lbs) as debated in this thread: http://www.m3post.com/forums/showthread.php?t=831495 Now another element that is making me ponder more is the size of the thread blocks (the width of the longitudinal grooves). As you can see from the pictures below, the longitudinal grooves on the 255/35R19 fronts on my ///M and on the 235/35R19 on my wife's S4 are significantly wider than the ones on my 275/35R19 rears. This results in significantly more rubber on the road for the 275. I am wondering if the 265/35R19 have wide grooves like the 235 and 255 or narrow grooves like the 275. If the grooves are wider on the 265 than the 275, it could make the extra weight of the 275 worthwhile... Please post pics of your 265/35R18 here 275/35 255/35 235/35 Last edited by CanAutM3; 06-02-2013 at 07:32 PM.. |
06-02-2013, 01:42 PM | #3 |
21121
Rep 20,741
06-02-2013, 02:35 PM | #4 |
21121
Rep 20,741
275 offers 20% more rubber on the road
OK, so I have done a little extrapolation based on the picture provided by Denk and some math to figure the difference between the 265 and 275.
Here are the results for thread block width in mm 265/35R19 (Total thread width 254mm) 47+32+32+32+47 = 191mm (75%) 275/35R19 (Total thread width 259mm) 58+38+38+38+58 = 230mm (89%) So even if the 275 total contact patch width is only 5mm wider than the 265 contact patch, it offers 39mm more rubber contacting the road because of the narrower grooves. This is 20% more. This could justify the 2.9lb of extra weight (+12%). Decisions, decisions... Last edited by CanAutM3; 11-18-2014 at 11:39 AM.. |
06-02-2013, 03:44 PM | #5 |
68
Rep 1,359
Yep, the 265's (which I have) have the wide groove. Definitely more contact with the 275's.
2014 E63 AMG-S
2012 C63 AMG (P31) - gone 2011 E90 M3 FBO - gone |
06-03-2013, 07:06 PM | #6 |
62
Rep 398
Anyone have any idea why for a 10 mm change in width, they change the grooves so much? It seems like they would follow some ratio that that was calculated to be optimal for tread width to grooves. Having increased traction is great, but for people who live someplace where it rains, it seems like a 275 would hydroplane way more than a 265. It also seems like a 275 might make it understear more with a 255 in the front with wide channels.
06-03-2013, 08:04 PM | #7 | |
21121
Rep 20,741
You are correct, the increased lateral grip provided by the 275 would shift the handling balance more toward understeer. |
06-03-2013, 10:03 PM | #8 | |
376
Rep 4,089
Drives: 21 X6MC
