      05-16-2013, 07:06 PM   #1
whostorm05
39
Drives: 2012 135i
Weisslicht LED side lens replacement - what am I missing?
I ordered a pair of smoked led side lenses from bimmian.com late last year.
I finally got around to installing them today and i'm confused. The box indicates they are for E90, 91, 92, 93, 82, 88, 87, 81 and 60. part number is lslxx1soh.
The connectors on the end of the replacement vs stock are completely different. Am I missing something here or did I get the wrong model?
See pic...
      05-16-2013, 07:35 PM   #2
iv-128i
iv-128i's Avatar
46
Drives: 2017 m240i, prior : 2011 128i
2011 BMW  [0.00]
you have to unclip the white piece from your OEM sidemarker. Turn it counter clock wise and you will be able to remove it. Then remove your OEM bulb and that's where you'll see the needed connector
M240i F23
      05-16-2013, 07:42 PM   #3
whostorm05
39
Drives: 2012 135i
So I have to re-use this white plastic connector? I can't seem to get the blasted thing off the stock lens.
      05-16-2013, 07:51 PM   #4
Jcrewsn
12
Drives: 2009 BMW 135i
2009 135i Sport  [0.00]
^ Ya that's probably because you can't just turn it and pull it out. You have to first pull up on the tab located on the gray part connecting to the white piece(nearest the o-ring) and then turn. I used a small screwdriver and just lodged it underneath the tab and then turned.
      05-16-2013, 07:56 PM   #5
whostorm05
39
Drives: 2012 135i
Got it. Smaller screwdriver helped. Thanks!
      05-16-2013, 08:11 PM   #6
Adam135
75
Drives: 2014 435i
How the F do you remove the lenses from the fenders? Mine don't budge.
      05-16-2013, 08:16 PM   #7
whostorm05
39
Drives: 2012 135i
What I did was slide the marker towards the side with the clip and then used a credit card on the other end to pop it out.
      05-16-2013, 08:46 PM   #8
Adam135
75
Drives: 2014 435i
Do you push the lenses towards the front or rear of the car?
      05-16-2013, 09:03 PM   #9
whostorm05
39
Drives: 2012 135i
For the passenger side I remember it was toward the front. I believe the driver side was the same but I don't remember as I did that one much quicker.
1addicts
