KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
05-15-2013, 10:40 PM | #1 |
248
Rep 1,373
HELP! I have some rubbing issues!!
Need some suggestions or advice!! I have an E90 M3 and I bought HRE P43sc a few months ago.. The car has no EDC at stock high there's is no rubbing until I hit big dips or bumps but not even a speed bump so it's not bad and I don't mind dealing with it. What the problem is that I want to lower it a lil because I think it needs a slight drop but I'm afraid the rubbing will be constant.. I was told that the PSS are too rounded and bulky. I don't think my wheel specs are the problem because I've seen similar specs with no rubbing at all. I took off my wheels last week and found that there's rubbing by the outer fender lining all around but what's weird is that all the rubbing marks aren't similar. For example my passenger side rear fender lining has a whole from the rubbing as the other side has a lil wear on it ?? Also if someone knows a local shop in NY that could help would be great also. Any advice would be great.
SPECS: Michelin PSS Front 9.0 x 19 ET 22 255/35 Rear 10.5 x 19 ET 27 295/30
2018 F80 M3 ZCP Mineral White- Extended Shakir Orange - Full Suntek Ultra Wrapped - ///M Performance Spoiler - RKP Front Lip - RKP Side Skirts - Vorsteiner GTS Diffuser -AA Mid-Pipe-///M performance HAS kit - HRE P101
11 E90 M3 JEREZ BLK METALLIC ZCP SOLD |
05-15-2013, 10:55 PM | #2 |
2741
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Negative camber
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
05-16-2013, 12:01 AM | #3 |
248
Rep 1,373
I know I was thinking of trying to avoid camber I'm not crazy about messing with the camber bc not crazy on how it would look
05-16-2013, 10:23 AM | #4 |
2741
Rep 6,734
I'm not talking about -4 degrees. The maximum negative camber you will reach is -2.0 +/- without camber plates. That is relatively mild and you have better eyes than I do if you can detect a significant difference between -1.2 and -2.0.
My old car with Eibach springs and -1.6 camber in the front, -2.1 camber in the rear with 275/30/19's on 9.5" et 22 wheels, 295/30/19 on 10.5" et 22 rear:
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 05-16-2013 at 10:32 AM.. |
05-16-2013, 10:36 AM | #5 |
2741
Rep 6,734
My current car with -2 degress +/- sitting much lower with 18 x 9.5 et22 front with 275/35/18's and 18 x 11 et18 with 285/35/18's. No rubbing (with the exception of a slight amount on the helper spring which is a KW clubsport issue). FWIW - I am currently running the front wheels at et15 (everything else the same) which has corrected the helper spring rub and added a slight rub at full lock). The point I am trying to make is that with a moderate amount of negative camber, you can run far more aggressive wheels / tires in the front and you should be able to eliminate your problems in the rear.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 05-16-2013 at 10:43 AM.. |
05-16-2013, 04:14 PM | #6 | |
336
Rep 2,940
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
05-16-2013, 04:17 PM | #7 | |
Croatian
884
Rep 3,613
Drives: PORSCHE
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
05-16-2013, 04:52 PM | #8 |
248
Rep 1,373
All four wheels are rubbing but the front aren't that bad their just touching it, the rears rub a lil more.. Again they only rub on full compression..
05-16-2013, 05:19 PM | #9 | |
2741
Rep 6,734
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 05-16-2013 at 05:27 PM.. |
