04-27-2013, 08:00 PM | #1 |
Rep 55
Help with Mediabridge install in 2006 Z4M Roadster
Hello,
I just started installing the DICE mediabridge. I watched the videos online from Bavarian Soundwerks. I'm having trouble accessing the necessary cables because I can't lift the trim up at all, due to the manual center storage compartment release cable being in place. This button is not shown in the videos I saw from Bavarian Soundwerks I attached a photo - it's the round little black button with a cable attached. Behind this button under the trim is a foam block. Does anyone have any suggestions on how to proceed? Is there a way of removing this so I can lift the trim up to expose more of the cables? Thank very much. |
04-27-2013, 10:09 PM | #2 |
93
Rep 413
When my son and I installed my Media bridge it was sufficient to kind of lift the bottom of the upholstery enough to check for the CD changer connector. Mine was located behind the stut/frame near the bottom that is basically right below the button shown in your picture. I just kind of felt around behind the structural pieces. It's going to be closer to the bottom than higher up.
Sent from my smart phone...
04-27-2013, 10:30 PM | #3 |
Rep 273
Pull the button away from the panel, and make a slit through the cable hole in the cardboard, just tall enough to slip the button through sideways. Then you can lift the panel and access the cables.
After you've made the connections for the mediabridge, just slip the button back through the slit from behind with your arm under the panel -there will be enough room to do that, then remove your arm and refasten the panel. The edges of the slit will come back together invisibly - and you won't see it anyway with the button over top. I ran the mediabridge cable sideways through the passenger side subwoofer opening into the passenger compartment, then tucked it under the console edge up into the cavity under the HVAC controls. The cable isn't visible at any point. Despite what some have reported, the unit has worked great for me, for both Bluetooth telephony and ipod connectivity. Have fun with it ... ! |
05-23-2013, 10:20 PM | #6 |
195
Rep 1,530
Drives: 2008 Z4 3.0si, 2013 E92 M3 ZCP
Glad to hear it worked flawlessly for you! Mine has been a nightmare. Did you get the dice version or the audiovox version just to clarify. I know I your original post you referred to it as the dice mediabridge. Thanks!
05-24-2013, 06:32 PM | #7 |
Rep 55
Hi there,
I got the DICE from Bavarian Soundwerks. http://www.bavariansoundwerks.com/pr...tegration-Kit/ I have it hooked up to an Ipad mini mounted on the central air vent and it has been working great so far. Hope this helps! |
05-25-2013, 12:22 AM | #8 | |
195
Rep 1,530
05-27-2013, 12:46 AM | #9 | |
Rep 55
So far so good for me, I have the LTE version but I've been tethering it to my phone so haven't needed to activate a plan as it's been working pretty well too. I'm sorry to hear about your current unit, hopefully a new one will do the trick.
I'm afraid I can't post photos for you right now as my car is getting some interior work done so it's in the shop for some time, but I will do so when I get it back again in a couple weeks if you're still interested then. Quote:
06-09-2013, 07:27 AM | #10 | ||
195
Rep 1,530
I have one more quick question regarding your set up. Did you connect your mediabridge microphone? Right now, when I make a phone call, the phone uses the Z4's OEM BT connection and microphone found in the steering wheel column. However, my wife says that when I have the top down, she can't hear me at all because of all the noise. Does the mediabridge microphone have any type of noise canceling technology that'll make it superior to use over the OEM BT? Thanks.
08-04-2013, 11:46 PM | #11 | |
Rep 55
08-28-2013, 11:30 PM | #12 |
HNIC
31
Rep 177
wow, this looks great. how durable is that mount? do you notice any excess vibration?
i personally don't really enjoy the factory nav, and i prefer to use Waze. I figure if i can tether my ipad mini to my phone, i can control music in the background, and any alerts from Waze would cut the music, and give me directions/warnings, etc. |
08-29-2013, 01:23 AM | #13 | |
Rep 55
Hi,
Yes that is exactly how I'm using it |
08-29-2013, 01:46 PM | #14 | |
HNIC
31
Rep 177
any worry about the mount itself falling off of the vents with spirited driving, hard accelerations, or hard cornering? I tried balancing my phone on the factory nav screen, but i'm worried that my phone will fly out the window at a hard turn, and it already has fallen down quite a bit after hard acceleration from a stop. i guess i'm just worried that the weight of the ipad mini might be too much (as light as it is). an iphone mount would be much simpler/sturdier but the screen is just too small for my crappy vision. plus, i'd rather be able to see what i need to at a quick glance and keep my eyes on the road rather than squinting at a tiny phone screen. |
08-29-2013, 02:08 PM | #15 | |
Rep 55
The mount came with screws to fix it to the air vent so you do need to screw into the vent from above and below to attach the mount, and you have to be careful with where to put the screw to not interfere with the directional fins in the vent. I don't think it was designed to hold the weight of the ipad mini with the proclip, so to be honest I just decided to give it a try. So far so good though and I don't see how it can break loose except with very great force (fingers crossed). The proclip is rated to withstand collision according to their website. In hindsight I think I would've ordered the proclip without the locking mechanism to reduce the overall weight.
09-03-2013, 11:30 AM | #16 | |
HNIC
31
Rep 177
