M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      04-07-2013, 06:14 PM   #1
Used2be
Perennial PFC
Used2be's Avatar
336
Drives: F90 M5 DG/Aragon
Will the 344M wheels fit the F10 M5?
I'm considering a second set of wheels for the M5 and since I like the stock 19" on the M5, and no aftermarket supplier seems to be inclined to make a 19" wheel that fits, perhaps the 344M wheel on the F13 M6 might fit? Does anyone know the answer to that? They are 1/2" wider front and rear, but if the offset allows I think they'd look good on the M5. I've an email in to GetBMWparts.com and hope they will know for sure.
      04-07-2013, 07:54 PM   #2
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
While I don't know for sure, they should fit. Much like the E60/E63, the F10/F13 have the same drivetrain. The E60/E63 had wheels that are interchangeable other than a slight difference in offset.
      04-07-2013, 07:54 PM   #3
koxal
koxal's Avatar
121
Drives: 2015 LBB F85 X5M
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
i am also looking for a second set for my car..
exploring the options and so far found these :
http://f10.m5post.com/forums/showthread.php?t=824889
pls also share your findings if u find something...
      04-07-2013, 07:55 PM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
since both have the same brakes, therefore, they should clear the caliper.
      04-08-2013, 06:52 AM   #5
Used2be
Perennial PFC
Used2be's Avatar
336
Thanks all for your input, and while I am pretty sure they will bolt on, it's the offset that will determine the fit. Most likely it will take mounting a set to see for sure. I was hoping someone might have already tried that.
      04-08-2013, 07:14 AM   #6
AGS
AGS's Avatar
501
If you have the specs of the M6 wheels, you can use this site:
http://www.rimsntires.com/specs.jsp?...&text1=&text2=
The specs on the 19" F10 M5 wheels are:
Width Diameter Offset
Front 9.0 19.0 32
Rear 10.0 19.0 34
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      04-08-2013, 08:24 AM   #7
Used2be
Perennial PFC
Used2be's Avatar
336
Thanks, didn't know of that site, it will help a lot!
      04-10-2013, 09:37 AM   #8
Used2be
Perennial PFC
Used2be's Avatar
336
I've been told that the specs for the 2013 M6 wheels are:
front width: 9.5" rear width: 10.5"
front offset: 31mm rear offset: 19mm
With the 2013 M5 wheels being:
front width: 9" rear width: 10"
front offset: 32mm rear offset: 34mm
I'd think the fronts should fit with no problem, but the rears would be .85" farther out with the .25" from the extra rim width and the .6" less offset. Likely some fender contact with that change. Also, the M6 wheels are about $400 per wheel more expensive than the M5, but listed as forged by BMW and so would probably be lighter as well.
I don't have much experience with wheel fitment, so any thoughts welcome.
m5post
