04-04-2013, 06:26 AM | #1 |
41
Rep 666
Advan performance, "Nashin BBK" April promo
Hi Gents,
in lieu of the "Taipei Int’l Auto Parts and Accessories Show" the guys at Nashin HQ have generously reduced our buy price for the entire month of April, in an effort to further stimulate the Aus' market. As such I have put together an assortment of BBKs at prices that are even better, than our "Time Attack" special from last year. The price shown is in AUD and inclusive of GST, however it does NOT include shipment outside of Sydney or fitment of the kit. N.B. The below pricing is ONLY effective for the month of April. All orders MUST be placed and payment confirmed before the 1st of May, in order to obtain these prices that are heavily reduced over retail. BBK #1, (19" wheel required). Front: 380 mm 2-piece Floating rotor/N7 (6 piston) Mono-block caliper with "Street" pads Rear: 345 mm 2-piece Floating rotor/N3 (4 piston) Mono-block caliper with "Street" pads Cost: $3,195.00 BBK #2, (possibly 18" wheel compatible, may require 19" wheel). Front: 370 mm 2-piece Floating rotor/N5 (6 piston) Mono-block caliper with "Street" pads Rear: 345 mm 2-piece Floating rotor/N3 (4 piston) Mono-block caliper with "Street" pads Cost: $2,945.00 BBK # 3, (18" wheel compatible). Front: 355 mm 2-piece Floating rotor/N5 (6 piston) Mono-block caliper with "Street" pads Rear: 345 mm 2-piece Floating rotor/N3 (4 piston) Mono-block caliper with "Street" pads Cost: $2,795.00 BBK #4 Front ONLY, (19" wheel required). Front: 380 mm 2-piece Floating rotor/N7 (6 piston) Mono-block caliper with "Street" pads Cost: $1,995.00 BBK # 5 Front ONLY, (18" wheel compatible). Front: 355 mm 2-piece Floating rotor/N5 (6 piston) Mono-block caliper with "Street" pads Cost: $1,545.00 For those guys that are not just after BBK bling and plan on tracking their cars, we can supply the calipers pre-loaded with Nashin's "Sport" pad. Front & Rear kit "Sport" pad upgrade is $95.00 Front ONLY kit "Sport" pad upgrade is $55.00 Lastly the standard slotted rotor can be swapped out for a cross-drilled rotor, at the cost of $125.00 per axle. However for track day enthusiasts I recommend the use of the standard non-drilled "Floating" rotor. For anyone that has not come across any prior information on our Nashin big brake kits, here is a link to my thread that should provide some interesting reading. http://www.1addicts.com/forums/showthread.php?t=677088 Cheers, Justin. |
04-04-2013, 11:55 PM | #3 |
41
Rep 666
Hey guys,
here are a few pics of the calipers from a N7 & N3 kit that were ordered with a non-machined logo surface, which is now an option when buying a N-Series kit. So for those BMW owners that want a BBK that looks less aftermarket and a little more OEM, we now have you covered. |
04-06-2013, 04:16 AM | #4 | |
376
Rep 668
How much are comparable offerings ( performance wise) from more recognized brands such as brembo and AP ? |
04-06-2013, 11:09 PM | #5 | |
41
Rep 666
make no mistake they "are" the business. IMHO you could not purchase a comparable offering from Brembo, AP Racing, StopTech, Alcon etc. for anything remotely close to what the Nashin BBKs are available for, not even at full retail pricing on the Nashin hardware. I am not going to try to convince potential purchasers that the Nashin kits are every bit as good as the "premium" kits from the above manufacturers, with "made in Taiwan" associated with Nashin that is a hard sell indeed. But you simply cannot buy this level of performance from the Big players without spending considerably more coin. What's more the Nashin BBKs whilst being very cost effective, work extremely well under demanding track conditions too. Originally Posted by pavo335 I went to the ARDC track day yesterday (good to meet you alex/dad and uncle, hope you finished ok)at EC which was set on the 'long circuit' as opposed to the GP curcuit. The Long circuit is much more technical and demanding than the GP curcuit. The ambient temps hit over 35 Deg so it was a hot one out there yesterday, with a couple of local cars pulling out due to heat after the second session. I made it to the 4th before i started getting a persistant limp (it could have been the first heat induced limp as oil was getting over 140) and i pulled in early. I started the 5th session and on the 3rd lap mid way through turn 1 I lost all power , when i managed to come to a stop i realised the engine had just cut out an required a full ignition off and on before the car would start. Well by this time I figured that was hint 2 and I was not real interested in what hint 3 was going to be so I packed up and went home. Why am I saying all this in a brake thread?????? Well this was the first REAL test I have hada chance to put the new Nashins through and I can say WOW. ZERO brake fade on a very warm day with new R888's on the front (which by the way i also highly rate). They stopped from the first corner to the last, with never a hesitation. In fact I pushed them 50% harder than the stockers (which imho are pretty decent on the 335) and they still have more to give. My only regret is that I should have gone for the smaller size up front so I could get an 18' rim on, so I would have a wider selection of tyres. Cheers, JD. |
