03-25-2013, 12:24 PM | #1 |
732
Rep 3,274
Linear springs for KW V1 / ST
I know HPA sells linear swift springs that work with KW V2 and V3, but have to be machined down by 1 mm to install correctly.
http://www.hpashop.com/KW-Swift-Spri...conversion.htm Anyone know if these work with KW V1 or ST coilovers (which I assume are the same) as well? If not, anyone know of any other linear springs that could work with STs? If it can work what would be a good spring rate for our cars that's more aggressive than the stock KW progressive ones, but not too much for the shocks to handle?
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
03-25-2013, 10:32 PM | #2 |
99
Rep 370
I'm also interested. I've seen Harold report that swift springs are much more durable, more consistent and better performers than the stock units for those. I wasn't aware of the machining needed tho. Hope your question gets addressed by those in the know.
03-26-2013, 05:34 AM | #3 |
172
Rep 2,347
I'd like to know as well
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
03-27-2013, 09:52 PM | #4 | |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
Remember, ST and V1 have progressive front springs, the upgraded Swifts will be linear rate so you will get more consistent performance just from that aspect alone. Let us know if you have further questions via PM or email as it is hard to keep track all the threads we have responded to. |
03-28-2013, 11:02 AM | #5 |
732
Rep 3,274
Thank you so much for the response! At first I was looking at 448f/616r but I guess that's too much for the calibration on the shocks to handle :P
Would you recommend getting just the fronts, or is there really that big of a performance difference when getting both?
