      03-22-2013, 05:29 PM   #1
The Black Pearl
Drives: 2008 135i
Angel Eye Alpinev3 replacement HID bulb
Anyone know where I can buy a replacement bulb for the Alex Alpine angel eye HID hit? I don't want to do any cutting, soldering....etc. Going to the AlpineMSS website has been proven unreliable....
      03-23-2013, 08:20 AM   #2
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
I'm going through the same thing, I actually filled a complaint with the better business bureau. Another member on here told me he got bulbs from ddmtuning.com for $15 and spliced in the connectors. I'm ordering them today so I can let you know how that turns out.
"Never attribute to malice that which is adequately explained by stupidity."
      03-24-2013, 01:57 PM   #3
The Black Pearl
Drives: 2008 135i
thanks, i appreciate that
      03-26-2013, 06:13 PM   #4
woahitsholland
woahitsholland's Avatar
Drives: 2010 135i
has anyone switched to H11 to see if it throws a code or not? Sorry to bump in on the thread but i'm new on here and am all done with engine mods and am looking into changing the lighting but doing it the right way. Theres a company called "Oracle" that makes lights and i have em' on my gsxr1000 but they don't make h8. they are 'plasma LED' which produce wayyyyy more light than your typical 26 bulb kit (or whatever they are).
here's a link....
http://www.automotivelightstore.com/...aLEDBulbs.aspx
      03-27-2013, 03:29 AM   #5
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
here's a link....
If you will try those please share the outcome I believe no body tried those here.
      03-27-2013, 08:30 PM   #6
woahitsholland
Drives: 2010 135i
i will then. i've put them in a few camaros and they light those rings up as bright as any audi and it looks great. i know the BMW's have the outer ring to worry about but if it looks good i'll make a thread about em. Think it will throw a code??
      03-28-2013, 04:42 AM   #7
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
I guess they will throw a code if voltage will be less than 35 watts but its possible to code out.
Although it says that bulbs are 41watt in that case should be fine without codes.
      03-28-2013, 09:14 AM   #8
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
My order from DDMtuning has shipped and hopefully will be here in a week so I will be able to update you on whether or not it was successful.
      03-28-2013, 11:46 AM   #9
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
So what exactly you ordered?
      03-28-2013, 04:37 PM   #10
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
I ordered H8 HID replacements. All I have to do is splice in the connector wires to connect them to the alpine ballasts.
      03-28-2013, 06:01 PM   #11
The Black Pearl
Drives: 2008 135i
I did the same as well
      03-28-2013, 06:13 PM   #12
int2str
int2str's Avatar
Germany
80
Drives: 2008 135i
I have not tried these "Oracle" LEDs, but I am running incandescent H11 bulbs. To make H11 bulbs fit into the H8 socket, you will need to grind one of the tabs to make it more narrow. Once you receive your bulbs, you'll see what I mean.
I usually make this mod with a Dremel. It takes only a few seconds per side. It's easiest if you remove the rubber seal at the bottom of the bulb first so that you don't accidentally break it.
H11 55w bulbs in very bright sunlight:
      04-03-2013, 12:35 PM   #13
woahitsholland
Drives: 2010 135i
i figured that. i ended up grabbing a set of 20 watt jtechs for 40 bucks and it looks awesome and no error cause it's 20 watt
      04-03-2013, 02:05 PM   #14
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Those looks good. How long are you running them?
Anybody tried those http://www.ebay.co.uk/itm/2908763854...84.m1436.l2648
      04-05-2013, 08:14 PM   #15
FDM68
FDM68's Avatar
Wake Island
34
Drives: 11' 135i
Puy in my BMS leds. Perfect. Kinda tight fittin but no codes and i packed the stuff away from the adaptive mechanics.
      04-05-2013, 09:52 PM   #16
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
Got my lights in from DDMtuning, the wiring looks almost exactly like the Alpine setup. One conntector has to be cut, I'll put pics up tomorrow of the wires that need to be cut and the lights installed. They are nice and white just like I was looking for and they are bright as hell!
      04-06-2013, 10:16 AM   #17
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
just don't forget to update with pics. Thanks
      04-06-2013, 07:16 PM   #18
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
Its really simple.
Pic 1 is the alpine light
Pic 2 is the DDMtuning light
all you need to do it cut off the connector in pic 2 and splice in the wires/block you cut off from the alpine light. The other side is the exact same without the block, its just one red and one black wire with either a male or female connector. I'll try and get some pics of the lights tonight and during the day tomorrow so you can see how they look.
      04-07-2013, 03:00 AM   #19
The Black Pearl
Drives: 2008 135i
Funny, I just installed my ddm headlights also, they are great, the splice was easy...
      04-07-2013, 07:48 AM   #20
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
I got the 6000k, which ones did you get?
      04-07-2013, 09:03 AM   #21
The Black Pearl
Drives: 2008 135i
8000k to match the DS1 8000k, I want to illuminate the dark skies where ever the black pearl goes....yeah that was very cheesy
      04-07-2013, 09:08 AM   #22
JK135i
8:39
JK135i's Avatar
37
Drives: 2010 135i
2010 135i  [9.50]
8000k have a slight blue to them right?
1addicts
