03-18-2013, 02:56 PM | #1 |
172
Rep 2,347
What eles should I do!
Guys gunna put the m3 subframe bushings in the rear what eles should I do while I have the car apart?!
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
03-18-2013, 03:53 PM | #3 |
European Editor
10589
Rep 22,992
Have some DOT4 brake fluid handy bc when the rear axle is lowered the brake lines have to come off/open - and later bled.
SS brake lines maybe? Make sure they are DOT rated. I would also do the M3 tension links (two per side).
03-18-2013, 05:35 PM | #4 |
172
Rep 2,347
Thanks
Yea brake lines and tension links are a great idea!
03-18-2013, 05:36 PM | #5 |
172
Rep 2,347
I really do want a limited slip but my funds can only go so far one day I will
03-19-2013, 06:01 AM | #6 |
22
Rep 277
Not trying to be a smartass, but shouldn't you have this planned out before you rip apart your car?
Do you have any other mods done or are the bushings the first thing? That will help people's suggestions.
2010 N54 135i - Alpine White - 6MT - M-Sport - LCI Blacklines - 1M Mirrors - PSS - Powdercoated Black 261M
SELLING MY CAR |
03-19-2013, 06:03 AM | #7 |
172
Rep 2,347
Well got the bushings along with m3 up and lower control arms I'm still deciding if I should go with coilovers or just a good spring and damper set up?
03-19-2013, 06:20 AM | #8 | |
22
Rep 277
Heh, we're in the same boat there. Let us know what you go with.
Another question that will help suggestions is what kind of drop do you want or can afford? If you want a big drop, coilovers are the easy choice. If you don't want a drop (like me) that is where it is trickier. Finding coilovers with very little or no drop isn't as easy. EDIT: Email from TCK I just received. Quote:
SELLING MY CAR Last edited by MLSavage; 03-19-2013 at 06:51 AM.. |
03-19-2013, 07:44 AM | #9 | |
172
Rep 2,347
04-18-2013, 12:10 PM | #11 |
172
Rep 2,347
Hey how's your setup?
Was wondering what you think of the springs after having them for awhile? idk if I should go an aftermarket route with the koni yellows? Any feed back is welcomed
04-18-2013, 12:11 PM | #12 | |
172
Rep 2,347
Did you ever pick a set up?
04-18-2013, 07:32 PM | #13 |
340
Rep 1,293
I've been running the TC Kline DAs with Swift springs (350/700) and all the M3 bits for about two years. I couldn't be happier with the ride and handling. It could be the length of the Swift springs, but on my car I found that the maximum height in the rear is about 3/4" lower than stock. I'm running the front slightly lower than the rear (approx. 1" drop) and have never had a issue bottoming out the car or suspension. This was by far the most rewarding mod I ever did. You won't be disappointed.
