03-05-2013, 07:54 PM | #1 |
68
Rep 397
CRT lip and damage
So,I was trying a new map on the jb4 and it worked well, well enough that I was at a very healthy speed before I thought of the crt lip mounted I had just purchased used and mounted, I was concerned that one end kept trying to separate slightly from the bumper, I was concerned about the way it was mounted and planned to redo this asap. The leading edge separated and got some decently bad road rash from dragging the leading edge on the asphalt, I am pretty bummed, just took it off as I should of as soon as I was suspicious. I'm hoping that I get some good ideas on repair and get it back on but not fond of a rashed up piece if noticeable at all. Ill post up some pics for advise as soon as I'm near a computer and hopefully the consensus is get it back on with a better mounting job. In the pictures I'm functionally concerned of one place on the leading edge that it wore through the carbon creating a hole and the drag that may create, as well as simply the cosmetics of the damage, it was purchased used and all the underside scrathches were there, just the front edge is my doing, I've had some bad luck with the 1M recently... Thanks for any advice.
Spencer
BSM 1M, MCS Coilovers, Pure Stg 2 Turbos, Walbro LPFP, JB4, BMS E85 Flash, ECS CF sealed intake, N54 Tuning DP's, Evolve Race Exhaust, Wagner FMIC, Stett CP w/ Tial BOV, ST BBK, Big Tires.
M6 6MT Gran Coupe w JB4, 718 GTS, Lotus Esprit V8TT, Duc 998SBayliss |
03-05-2013, 09:44 PM | #2 |
378
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
03-06-2013, 06:51 AM | #3 |
Just one more taste...
566
Rep 2,011
what?
My Build Thread: Jet Black 6MT 128i with MSport
03-06-2013, 10:01 AM | #4 |
68
Rep 397
Pictures
Sorry for the delay on pictures, just looking for ideas on repair, if its a good idea or bad idea funstionally to ermount it etc. I plan to attempt to clean it up and clear coat the damaged part and remount and see how it looks but if anyone has repair ideas or a place in so fla that they recommend let me know. Long term I think I'll need a new one but maybe I'll be happy once repaired and on the car, for reference the end with an obscene amount of double sided tape was the side pulling off:
03-06-2013, 10:04 AM | #5 |
68
Rep 397
My whiny feelings exactly, life goes on and hopefully the opinion is the functional side, what little there was, hasn't been affected much and it looks good when mounted with some sanding and clear coat.
03-06-2013, 10:56 AM | #6 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
Fiberglass patch it from behind, fill it, and paint it black. You don't need a new one.
Lips break. It just happens and is nothing to be embarrassed about. |
03-06-2013, 10:58 AM | #7 |
166
Rep 2,926
I don't think you will be able to patch the cf without stripping a large portion of the front end of the lip... Since it is a small area you might be able to resin it again then wet sand the areas you don't like and re apply clear cost on specified areas making sure to not hit the cf areas and risk more fray..
03-06-2013, 12:50 PM | #8 |
378
Rep 5,730
Drives: BMW i3 rex
looks a lot worse than i had imagined
03-06-2013, 04:21 PM | #9 | |
68
Rep 397
