03-04-2013, 04:55 PM | #1 |
78
Rep 818
My Dyno Chart
3 quick pulls, hardly a break in between pulls. CA 91 pump. Not sure why the car kept making power with each successive run though... Thoughts on that?
2016 F82 ZCP / 6MT / SSR Intake / Volk ZE40 18x9.5 et20 & 18x11 et34
Nitto NT01 265/40 & 305/35 / Macht Schnell Sport Competition Springs |
03-04-2013, 05:58 PM | #2 |
25
Rep 873
Kept making more power due to adaptations. If you could have watched live data i am sure you would have seen fuel pressure on the rise after each run.
03-04-2013, 11:14 PM | #3 |
78
Rep 818
^ got it. thanks for the insight. i wonder if it would gone up a bit if the dyno operator was aware of how our ECUs operate?
03-05-2013, 01:59 AM | #4 | |
25
Rep 873
03-05-2013, 07:00 AM | #5 | |
1122
Rep 7,690
Adaptations and fuel pressure don't seem to be related; not sure how they could be either because of the way injectors work. The ECU controls fuel pressure. It has two settings: 3-bar, and 5-bar. You can data log this with a BT tool if you want to learn more about it. |
03-05-2013, 07:05 AM | #6 | |
59
Rep 2,186
Vf supercharger + tune/H&R coils/ Akra evolution exhaust/Volk te37/ Rs-3 tires/ Brembos /TIal BOV/ OSS blacked out headlights/LUX v3/Led taillights/ Challenge Front lip/ P3 vent gauge/ F10 m5 shift mob/Matte black front grills/ And a funky air fresher
03-05-2013, 01:05 PM | #8 | ||
25
Rep 873
03-05-2013, 01:18 PM | #9 |
19
Rep 426
There is a difference between adaptions and adjusting timing on the fly. If you were driving with no WOT runs in awhile and you stick it on the dyno, it makes total sense that each WOT run may push the timing further as when in WOT mode it will try for the targets. You may not hit them at first because its too agressive but will settle out and find a timing that you can achieve which is higher than when you started. That is not an adaptation but rather the knock system sensitivity is always working to make changes second by second.
Adapations like long-term fuel trims would not be effected on WOT runs as those are established and do not change from slow driving to WOT. A/F doesn't really have adapations unless there is a problem of some sort. If you simply do pulls and log timing you probably will see you closer to hitting max timing with each pull which explains this. Eventually you either hit the max target or you max out timing given your octane even if not able to hit max target of 32 degrees and then you would stop making power and eventually if heat was an issue start to lose power again because timing would be pulled. |
03-05-2013, 01:25 PM | #10 | |
25
Rep 873
Understood. I am talking a bit in generalities here as the OP had a simple question that did not require him pursuing a master tech position. Good explanation though. I was on the Dyno last week after a re-tune and watched fuel pressure go, in order, from 82psi 1st run, 88psi 2nd, 105psi 3rd. I was just trying to shed some light for the OP.
03-05-2013, 03:21 PM | #11 | |||
1122
Rep 7,690
I'm also going to suggest if you can hook your car up the BMW diag tools (not BT tool) to see what adaptations are stored and not stored. I know there's a list of 10 adaptations that are stored, but I don't remember all of them off the top of my head. Heck, I don't remember hardly any of them off the top of my head. But I don't think there's anything in there for cam timing adaptations (that wouldn't even make sense). I think you'll find things mostly like AFR trims that are intended to compensate for the degradations in the o2 sensors and CAT converters. I only know of one guy who data logged fuel pressure, and all I can say is that I don't think it has anything to do with adaptations and the data showed a 3-bar setting and 5-bar settings. I don't think that data was ever published, but I know it exists. So I can't point you to a public place to show you this data. But I can ask the guy who logged it if he might consider posting it. But I'm very interested to see what data logs you have. So please post them so we can all learn and I'll see if I can do whatever I can to help you learn from our data as well. |
03-05-2013, 03:29 PM | #12 |
5234
Rep 10,616
The AFR all look very close at peak power. Does this ECU really use fuel pressure rather than injector pulse in order to hit the programmed AFR target? The variations are within 2%, and you can get that just about anytime you do several runs on a dyno. I am not sure whether I would draw any conclusions from the results, and that it may be just coincidental that power increased each run. You would have to log to see what actually changed.
03-05-2013, 06:23 PM | #13 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
Fuel pressure is once removed from the actual performance determinant. An increase in fuel pressure would only provide resolution to a condition where the AFR were too lean.
In other words, the relevant metric that determines output performance is AFR, rather than fuel pressure. If your AFR consistently shows too lean, you start looking for fuel pressure issues, rather than the other way around. ... unless you did a diesel conversion on your M3, then you always want MOAR FUEL!
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
03-05-2013, 07:44 PM | #15 | |
721
Rep 3,964
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
