BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
European Auto Source (EAS)
      08-31-2007, 08:35 AM   #1
dechoong
26
Drives: E60 530 Sport
Technical Question
I'm curious, is the rear diffuser on the E92 M3 a working device or just a showpiece? I'm no aerodynamicist, but doesn't the airflow under the car needs a clean line (hence the partially covered underbody) for the extractor/diffuser to work properly at the rear? If so, why is the big exhaust silencer situated right in the middle of the airflow channel towards the diffuser?
      08-31-2007, 08:42 AM   #2
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
The exhaust in the middle may reduce the diffuser effect, or as you say it may be just marketing with no real effect, but the exhaust in the middle does not necessarily preclude the entire diffuser effect. In other words, I don't think you can eyeball it and conclude there is no ground effect. Just as you cannot eyeball an F-117 and say it will fly.
      08-31-2007, 09:15 AM   #3
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
I have heard the exhaust housing actually directs air.
      08-31-2007, 09:24 AM   #4
swamp2
swamp2's Avatar
611
Drives: E92 M3
Aerodynamics
The role of aerodynamics is primarily three fold:
1. Low drag for higer speeds with less power
2. High down force for ability to corner at high speeds, also for general stability.
3. Cooling (engine, brakes, transmission, electronics, etc)
The reason to have the bottom of the car covered is indeed to promote high speed laminar flow under the vehicle. The adds down force. Running a flat smooth underbody with no rear diffuser leads to increased drag when the underbody flow mixes and forms turbulence behind the car. A rear diffuser mitigate this by mixing the underbody flow into the vehicles wake.
OK...back the the M3...Given that the car does have a fairly smoothed flat bottom there is a definite need for a diffuser. Although the design on the exterior of the car looks nowhere near as dramatic as on many other cars (F430 for example) I suspect it does have significant function. I also remember reading (I think from the long BMW press release) that the entire design of the underbody and diffuser also contributes to cooling its trick M differential. Although not based on facts, published statements, CFD or wind tunnel evidence BMW M is well known for designs that emphasize function over form and I seriously doubt they would have a non-functional rear diffuser on the car.
      08-31-2007, 10:17 AM   #5
dechoong
26
I've read from F1 articles that heated air travels faster. From the picture of the M3's rear undercarriage, it does seem there's a lot of heat created just before the rear diffuser from both the exhaust silencer and the M differential's heatsink. I would think the heated air is accelerated through the diffuser to create downforce and cool the M differential at the same time.
But the M3's underbody does look pretty messy at the rear with many exposed mechanical components. Wish they would clean up the airflow of the car by testing it in their F1 windtunnel at Hinwil. It's no coincidence cars like F430, R8 etc have their undercarriage almost totally covered.
      08-31-2007, 10:19 AM   #6
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
Do I see a scratch mark on that muffler?
      08-31-2007, 10:25 AM   #7
dechoong
26
This pic was taken by another member of this forum... just using it to illustrate the topic on discussion here
      08-31-2007, 11:50 AM   #8
phoenixbmwlife
phoenixbmwlife's Avatar
1913
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Looks like that would be one of the aftermarket parts to get for the E92 M3. "An underbody cover to compliment a lighter and sportier exhaust"
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      08-31-2007, 11:57 AM   #9
mkoesel
Moderator
7516
Drives: No BMW for now
Is that how the E92 in the pic a final production vehicle (or at least built like one)? It looks like a lot less underbody covering than on my E46.
      08-31-2007, 06:30 PM   #10
Stahlgrau
Drives: Backwards
I believe that picture was taken with the underbody cover removed. Or, that's what I remember anyway.
      08-31-2007, 09:21 PM   #11
heyimsexy
Drives: e36
i dont think ive ever worked on a car that had paneling covering the rear.....its usually only on the front, yeah?
      08-31-2007, 10:08 PM   #12
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
I believe so.
      09-02-2007, 04:54 AM   #13
swamp2
swamp2's Avatar
611
Drives: E92 M3
All the answers
Wait... epiphany... I got it
The muffler is so ugly that the surronding air will be really scared of it thereby moving faster around it and providing a "super diffuser" effect. Yeah BMW.
m3post
