      02-28-2013, 03:29 PM   #1
HP Autosport
Supreme Allied Commander
3843
Drives: F80 M3
Smile Forge Motorsport uprated Intercooler for BMW 1M
This uprated intercooler has been designed for the BMW 335 equiped with the N55 (single turbo), and 1M equiped with the N54 (twin turbo) 6 cylinder engine. Our criteria was to achive maximum efficiency whilst retaining a simple fitment. With our testing results indicating increased cooling of up to 30 degrees centigrade and the ability to install this on your driveway at home in under one hour, we have just what we wanted.
After considerable trials with different intercoolers cores, we found that the most efficient for these models, was a core of bar and plate design, and along with an overall increase in dimensions we have been able to improve the cooling ability and reduce the pressure loss across when compared to factory intercooler. In the construction we use CNC machined bayonet couplers which allow an easy plug and play install. The intercooler is supplied with easy to follow instructions and all the parts required.
A reduction in coolong across the rev range with up t0 30 degrees centigrade differential.
Installation instructions:
http://www.forgemotorsport.com/media/FMINT1M.pdf
$1100
Order here:
http://www.hpashop.com/Forge-Motorsp...N54-335-1M.htm
      03-12-2013, 02:36 PM   #2
HP Autosport
3843
Drives: F80 M3
We will put the Forge unit up against the ETS soon!
      03-13-2013, 08:02 PM   #3
E30 Racer
E30 Racer's Avatar
220
Drives: '11 1M, '09 335i M Sport
Sure is pretty...look forward to the comparison!
      03-27-2013, 07:03 PM   #4
HP Autosport
3843
Drives: F80 M3
Originally Posted by Ian///M View Post
Any results yet?
No, not yet.
      05-02-2013, 11:44 AM   #5
HP Autosport
3843
Drives: F80 M3
One unit without a good home!
Next batch is due in 3 weeks!
      05-02-2013, 12:00 PM   #6
HP Autosport
3843
Drives: F80 M3
Any results yet?
Dyno here. ETS(Black)vs. Forge(Red)
      05-09-2013, 01:04 PM   #7
Zombie1
172
Drives: BMW 135i 2010
Nice #s this won't work with n54 135i with out cutting stuff?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
      05-14-2013, 12:35 PM   #8
HP Autosport
3843
Drives: F80 M3
No cutting on this one!
      05-14-2013, 12:43 PM   #9
Zombie1
172
Awesome!
So it will fit the 135i? I was confused cause your site says 335i and m1 but if it fits with no problem I got to get one!
      05-14-2013, 01:03 PM   #10
HP Autosport
3843
Drives: F80 M3
We just don't have it listed that way, but we will add the 135i to the application.
      05-21-2013, 01:30 AM   #11
4thM3
4thM3's Avatar
29
Drives: 2020 M2 Comp. Alp. White
Got mine last week. Now I just need to find a few minutes to install. Thanks for your help Harold..
David
      05-24-2013, 08:44 PM   #12
HP Autosport
3843
Drives: F80 M3
David
Can't wait to read your review!
      08-15-2013, 05:54 PM   #13
1911A145
1911A145's Avatar
34
Drives: 135i
Am I missing something here? Or is the Forge 400 or more dollars over the ETS at a marginal increase in power increase? The test were done on different days and who knows what changed between that time, too.
But... damn it looks nice as hell. I think they are both solid units. Did you test the 7" ETS intercooler compared to this? I think that would be more fair for the money. Unless you did, then ignore this entire post. lol
| COBB E30 | VRSF DP's | ETS 5" FMIC | BMS DCI |
393 RWHP / 434 RWTQ
      08-15-2013, 07:05 PM   #14
HP Autosport
3843
Drives: F80 M3
Both ETS and Forge are 5" units so I think it's a fair test, temperatures and humidity were nearly identical.
No oil deposits in either unit.
Yes, both are good units. I kept the Forge on my 1M because I am just tired of dealing with silicon couplers and t-bolt clamps that can be hard to access.
      08-15-2013, 07:20 PM   #15
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Drives: 135i - DCT - N55
So $ wise spent, which one will be better, not trying to debate here but interested to know as both Forge and ETS are quality products.
      08-20-2013, 12:45 AM   #16
HP Autosport
3843
Drives: F80 M3
ETS is obviously the less expensive unit here, but if were up to me I would still spend the extra money to get a direct fit unit with slightly better performance.
      11-12-2013, 03:00 PM   #17
HP Autosport
3843
Drives: F80 M3
Even a better deal, Forge IC is 10% off until Jan. 6th and we have them in stock!
      11-12-2013, 04:48 PM   #18
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Harold, can PM me a price delivered to Melbourne, Vic 3179, australia?
Thanks.
      11-13-2013, 12:44 AM   #19
HP Autosport
3843
Drives: F80 M3
Thanks.
PM Sent!
      11-13-2013, 03:16 AM   #20
a7med606
a7med606's Avatar
Bahrain
41
Drives: 1 ///M + F80 M3
i like it but i have few questions compared to other intercoolers who needed to cut a little from the connecting pipes , they look to have more diameters in the intercooler outlet pipe
like the ETS and the other FORGE intercooler , does it make difference in power gains or the air flow ?
i like the stock looking and no cutting require IC but want to know if the others will gian more power and better air flow to the charge pipe
      11-13-2013, 03:50 AM   #21
GeeRam
GeeRam's Avatar
195
Drives: X5 40d SE
I had one of these Forge FMIC's fitted to my N55 135i last February
OEM next to the Forge
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass.
      11-13-2013, 11:31 AM   #22
HP Autosport
3843
Drives: F80 M3
Please see post #7 for the answer to your question.
1addicts
